GeneDavis Posted January 22, 2025 Share Posted January 22, 2025 @MarkMc posted a plan in another thread about this topic, but there was no explanation about how things get done. Here is the plan he posted, but with the addition of a dishwasher symbol I made by importing a Sketchup model of a GE Monogram one at 18" width. In Mark's plan, he has a cabinet in which is a DW, one from the Chief manufacturer bonus library. The cabinet has no sides, no back, no fronts, no toekick, no nothing. It is just blank space with a countertop over. If I try to make such a cabinet, I fail. Going to the fronts section of the cab spec, I delete everything. Separations, door, drawerfront. I specify the cab as framed just as Mark has it. I specify the stiles as 0". I cannot get the cab to build blank, but always end up with a back and sides. I want a "cabinet" that is blank like Mark's but has the 18" width needed for this Monogram DW. What do I do? dishwasher hidden cabinet.zip Link to comment Share on other sites More sharing options...
DeLayDesign Posted January 22, 2025 Share Posted January 22, 2025 5 minutes ago, GeneDavis said: @MarkMc posted a plan in another thread about this topic, but there was no explanation about how things get done. Here is the plan he posted, but with the addition of a dishwasher symbol I made by importing a Sketchup model of a GE Monogram one at 18" width. In Mark's plan, he has a cabinet in which is a DW, one from the Chief manufacturer bonus library. The cabinet has no sides, no back, no fronts, no toekick, no nothing. It is just blank space with a countertop over. If I try to make such a cabinet, I fail. Going to the fronts section of the cab spec, I delete everything. Separations, door, drawerfront. I specify the cab as framed just as Mark has it. I specify the stiles as 0". I cannot get the cab to build blank, but always end up with a back and sides. I want a "cabinet" that is blank like Mark's but has the 18" width needed for this Monogram DW. What do I do? dishwasher hidden cabinet.zip 4.01 MB · 0 downloads I haven't opened the zip file, but have you tried selecting 'filler' in the general options of the cabinet. This should turn off everything except the front Link to comment Share on other sites More sharing options...
GeneDavis Posted January 22, 2025 Author Share Posted January 22, 2025 I did not try that but it is not checked filler in Mark's. Link to comment Share on other sites More sharing options...
SHCanada2 Posted January 22, 2025 Share Posted January 22, 2025 I compared the object properties of his vs me dropping the CA chef series dishwasher into a cabinet these are where his differ...that look like it might be what he did. The first one below is "side type" from the screenshot I put above (which is the chef series wiht right side set to none, and you can see the right side missing. right_side --------------------------------------------------------------- -------------------------------------------- NVPublisher actual_type ---------------------------------------------------------- "None" -------------------------------------- String left_side ---------------------------------------------------------------- -------------------------------------------- NVPublisher actual_type ---------------------------------------------------------- "None" -------------------------------------- String back_side ---------------------------------------------------------------- -------------------------------------------- NVPublisher actual_type ---------------------------------------------------------- "None" -------------------------------------- String has_toekick -------------------------------------------------------------- false --------------------------------------- FalseClass chef series with the above set like Mark's Link to comment Share on other sites More sharing options...
GeneDavis Posted January 22, 2025 Author Share Posted January 22, 2025 Chief's training video shows @scottharris placing a DW into a cabinet and he says the appliance replaces the cabinet, but it does not, really. The appliance symbol is positioned so that its front faces are outside the face of cabinet. @MarkMc does something completely different and I want to learn how to do what he does, because it models the appliance the way it actually sits, that being in a void the width of the the appliance. Link to comment Share on other sites More sharing options...
SHCanada2 Posted January 22, 2025 Share Posted January 22, 2025 5 hours ago, GeneDavis said: because it models the appliance the way it actually sits, that being in a void the width of the the appliance. isnt that what I showed above, take off the side and back panels of the cabinet, and the toe kick? you are just left with the countertop, which is what it would be IRL Link to comment Share on other sites More sharing options...
rwdozier Posted January 22, 2025 Share Posted January 22, 2025 FWIW, in the past I could not see the dishwasher "cabinet" in a material list or cabinet schedule until I realized this from a post of mine in 2020: Link to comment Share on other sites More sharing options...
MarkMc Posted January 22, 2025 Share Posted January 22, 2025 15 hours ago, GeneDavis said: Going to the fronts section of the cab spec, I delete everything. Separations, door, drawerfront. I specify the cab as framed just as Mark has it. I specify the stiles as 0". I cannot get the cab to build blank, but always end up with a back and sides. Not sure what you are doing. The only thing I find may be different-start with framed and separation set to zero, then place the appliance in front. Then no top, no bottom, sides and back to none, toe to 0,0 then uncheck. I managed to do with your symbol and then with symbols adjusted. Plan has yours on left, then adjust to sit on floor, then adjusted to floor and resize within the toe kick. NOTE that as I was wrapping up realized the the door on that dishwasher will sit proud of the adjacent cabinets. See below. I only did this because you asked and to see what happened. I never use this method. I always have custom countertops so no need there. Normally I make these from cabinets without using an appliance at all. If appropriate I make a door symbol by deleting surfaced from the appliance and converting to symbol. That gets the look and the counter along with correct spacing between cabinets. In this case where to resize height is important and I did not look up specs and haven't done an 18 in a long time so that's up to you. Included top right of plan. Alternatively, I might place as freestanding object and fill in the countertop. In that case the symbol needs adjustment- example bottom right. 18 DW.zip Link to comment Share on other sites More sharing options...
