TMKDrafting Posted Monday at 05:07 PM Share Posted Monday at 05:07 PM I'm wondering how I would go about removing these lines from my interior elevations? The lines are where 2 wall types join at an intersection. The right side of the line is an exterior wall, left side is an interior wall. Plan view is included to show the intersection. Thanks! Link to comment Share on other sites More sharing options...
ericepv Posted Monday at 05:39 PM Share Posted Monday at 05:39 PM What you are seeing is the joint between your interior wall and exterior wall. Make sure the interior surface of the two wall types are aligned and that should eliminate the line. Link to comment Share on other sites More sharing options...
TMKDrafting Posted Monday at 06:11 PM Author Share Posted Monday at 06:11 PM That's my issue... they're perfectly aligned and all interior material is the same. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted Monday at 06:29 PM Share Posted Monday at 06:29 PM Post the Plan Link to comment Share on other sites More sharing options...
BenPalmer Posted Monday at 06:55 PM Share Posted Monday at 06:55 PM You have multiple instances of 'Rabs Drywall'. Merge them together and that will remove your line. 1 Link to comment Share on other sites More sharing options...
DBCooper Posted Monday at 07:04 PM Share Posted Monday at 07:04 PM Not only is "rabs drywall" duplicated 3 times, but you have lots of other materials that are duplicated. Go into your plan materials, purge the unused ones, and then merge all of the duplicates. Extra lines are almost always caused by duplicate materials. Link to comment Share on other sites More sharing options...
TMKDrafting Posted Monday at 07:04 PM Author Share Posted Monday at 07:04 PM How would I go about merging them? Sorry... still learning a lot of the tricks with just 5 months into using CA. Link to comment Share on other sites More sharing options...
BenPalmer Posted Monday at 07:07 PM Share Posted Monday at 07:07 PM 3D>Materials>Plan Materials Multiple select all instances and 'merge'. Link to comment Share on other sites More sharing options...
TMKDrafting Posted Monday at 09:10 PM Author Share Posted Monday at 09:10 PM Awesome! That worked perfectly!!! Thank you all for your help. I'm going to go into my template and make sure that everything is merged there before starting my next project. Thank you all again and Merry Christmas!!! Link to comment Share on other sites More sharing options...
Renerabbitt Posted 18 hours ago Share Posted 18 hours ago On 12/23/2024 at 10:39 AM, TMKDrafting said: Here you go! Floor Plan-n.zip 10.37 MB · 25 downloads Thanks to whoever took this floor plan down. It was downloaded 29 times and is my proprietary work product, I would appreciate it if those that downloaded it do not distribute it. Link to comment Share on other sites More sharing options...
