Garreth Posted March 18, 2015 Share Posted March 18, 2015 Hi all, just trying to find out if there is a way in plan view of showing flexible duct for air con. Most air con consultants use some cad polyline with a lisp routine that converts it so it looks like a slinky...any thoughts. Otherwise I will just use a polyline. thanks Garreth Link to comment Share on other sites More sharing options...
Gawdzira Posted March 18, 2015 Share Posted March 18, 2015 I generally use a polyline with a dashed line and choose a very light gray color with a line weight around 100. Link to comment Share on other sites More sharing options...
jcaffee Posted March 18, 2015 Share Posted March 18, 2015 Molding polyline (create your shape first) then apply the spiral duct as the "molding" jon Link to comment Share on other sites More sharing options...
joey_martin Posted March 18, 2015 Share Posted March 18, 2015 CAD>LINES>CREATE LINE TYPE> Make a line that says FLEX in it and save it to the library. Link to comment Share on other sites More sharing options...
ACADuser Posted March 18, 2015 Share Posted March 18, 2015 Use text at a height you need. Try this ()()()()()()()()()() or this \/\/\/\/\/\/\/\/\/\/\/\/\/\/\ Link to comment Share on other sites More sharing options...
ACADuser Posted March 18, 2015 Share Posted March 18, 2015 If you are using Autocad try this LISP: http://www.theswamp.org/index.php?topic=19272.0 ;;;=======================[ FlexDuct.lsp ]==============================;;; Author: Copyright© 2014 Charles Alan Butler (CAB);;; Contact or Updates @ www.TheSwamp.org;;; Version: 2.3 Dec 28,2014;;; Purpose: Create Flex Duct from a centerline that the user picks;;; Centerline may be anything vla-curve will handle;;; 12.28.14 added Rounded duct surface;;; Sub_Routines: ;;; makePline which creates a LW Polyline;;; Restrictions: UCS is supported;;; Duct Layer is hard coded, see var Flexlayer;;; Debug only error handler at this time;;; Known Issues:;;; Tight curves cause pline jacket distortion;;; Added warning when this is about to occur;;; Returns: none Or use a home made linetype Link to comment Share on other sites More sharing options...
ACADuser Posted May 1, 2019 Share Posted May 1, 2019 Though I would post my Autocad LIN file if anyone wants to try them. CAB2.lin Link to comment Share on other sites More sharing options...
Alaskan_Son Posted May 1, 2019 Share Posted May 1, 2019 Polyline Distribution Path with a CAD Block assigned... 2 3 Link to comment Share on other sites More sharing options...
Michael_Gia Posted May 2, 2019 Share Posted May 2, 2019 What’s the cad block you assigned? Link to comment Share on other sites More sharing options...
Michael_Gia Posted May 2, 2019 Share Posted May 2, 2019 Ah! Link to comment Share on other sites More sharing options...
