ProfessorChaos Posted March 3, 2015 Share Posted March 3, 2015 This is an issue that came up a few months ago - very briefly - but has been occurring more and more as of late. Without any logical reason I can verify, I will be working away in Chief and all of a sudden it will switch me over to "Concentric" behavour patterns. If I toggle it off it then switches over to the "Move" behavour, even though my default is always selected. This can last anywhere from 20 seconds to an entire afternoon, and then all of a sudden, it will go back to how it should be.... I am running X3 so I hope this isn't a sabotage Chief Architect is running to force me into a software upgrade, Or perhaps this is a Computer issue. Either way, it has left me very confused, and very frustrated. Any and all guidance will be greatly appreciated. Thanks - Chaos Link to comment Share on other sites More sharing options...
DRAWZILLA Posted March 3, 2015 Share Posted March 3, 2015 You may have hit the hot key for that, change the hot key of delete it. Link to comment Share on other sites More sharing options...
ProfessorChaos Posted March 3, 2015 Author Share Posted March 3, 2015 What is the command called? isn't there a specific hot key for each of the possible behaviors? I don't think it is a hot key issue, but I am willing to try anything. Just not entirely sure what you are referencing here, Perry... Link to comment Share on other sites More sharing options...
ProfessorChaos Posted March 3, 2015 Author Share Posted March 3, 2015 I can say with full confidence it is not an issue with Hot Keys. I had the "Default" set to a specific hot key for when this did occur, and pressing it did not solve the issue. I have reset all my hot keys and checked, double and tripped checked preferences that states I am on "Default" but it still behaves like it is set to "move" Link to comment Share on other sites More sharing options...
DRAWZILLA Posted March 3, 2015 Share Posted March 3, 2015 Just thinking that "c" is the default for concentric mode, could be very easy to accidently hit it, I know I've don it. Just trying to help that's all Link to comment Share on other sites More sharing options...
jcaffee Posted March 3, 2015 Share Posted March 3, 2015 Intermittent issues are usually hardware related. A good place to start is testing your RAM to ensure there's not a wonky chip... http://memtest86.com/ jon Link to comment Share on other sites More sharing options...
DavidJPotter Posted March 3, 2015 Share Posted March 3, 2015 I still run 7-X7 and all run just fine, so I agree with Jon in that it is probably something with your PC and its hardware as opposed to Chief (any version) DJP Link to comment Share on other sites More sharing options...
dshall Posted March 3, 2015 Share Posted March 3, 2015 Just thinking that "c" is the default for concentric mode, could be very easy to accidently hit it, I know I've don it. Just trying to help that's all I think Perry nailed it. Try turning off that hot key, I bet you will not see the problem again. Link to comment Share on other sites More sharing options...
Doug_Park Posted March 3, 2015 Share Posted March 3, 2015 The C and , (comma) keys are hardwired in to be in concentric while it is down. It is not a toggle as such so doesn't seem like it explains the problem. It is also tied to the X1 button on your mouse. Try using a different mouse for awhile and see if the problem goes away. It could be a malfunctioning mouse button. Link to comment Share on other sites More sharing options...
glennw Posted March 4, 2015 Share Posted March 4, 2015 Do you get the behaviour indicators next to the cursor when this happens (make sure you turn on in Preferences first). Link to comment Share on other sites More sharing options...
