NeilofOZ Posted March 5, 2024 Share Posted March 5, 2024 Have imported a tile Image, but getting no where with use of this material. Have seen a video many times, but it does not make it clear on info required, I can the fill the chosen area wirh the image but only as a single image, not as tiles. Have attached 3 pics showing location ( Entry ) and screen shots of Pattern/Texure, tiles are 600 x 600. Link to comment Share on other sites More sharing options...
ericepv Posted March 5, 2024 Share Posted March 5, 2024 I can't inspect your file but the material you specified appears to be a slab and not a tile which means you will not get a pattern with grout lines. The pattern you selected in the 'Pattern' tab does not effect 3D when you are viewing in standard mode (only Technical, Hand Drawn or Vector). Try using Substance Player to make your material: Stone Designer https://www.stonecurators.com/stone-designer/ also works well Link to comment Share on other sites More sharing options...
robdyck Posted March 5, 2024 Share Posted March 5, 2024 Find a tile material in Chief's library that shows a tile using only 1 tile for the texture. Copy that material to the User library and then replace the texture file with your own texture file. That would be a good exercise to start. The DalTile library also has plenty of materials that would serve as a good starting point for texture replacement. Link to comment Share on other sites More sharing options...
CADustin Posted March 5, 2024 Share Posted March 5, 2024 9 hours ago, NeilofOZ said: Have imported a tile Image, but getting no where with use of this material. Have seen a video many times, but it does not make it clear on info required, I can the fill the chosen area wirh the image but only as a single image, not as tiles. Have attached 3 pics showing location ( Entry ) and screen shots of Pattern/Texure, tiles are 600 x 600. Hey Neil, looks like you have your "Scale" in the texture Panel set to 0mm on both the X and the Y. Scale is the size Chief makes the material show as before it repeats on itself and setting it to 0 makes it behave as if "Stretch to Fit" was active so your single tile is being stretched to fit the surface you apply it to. Try setting the "Scale" to be the dimensions you'd like the single tile to be and see what you get, if that's still not working let me know and we can try some more solutions. Link to comment Share on other sites More sharing options...
NeilofOZ Posted March 6, 2024 Author Share Posted March 6, 2024 Dustin, I know where you are coming from, but have done so many configurations its not funny any more, I can't recall having this many issues with X13. Have attached enlarged image which which allows for 600 x 600 tile size and it appears it showing only the horzontal direction not the vertical. The config. of this image is based on 600 x 600 tile and repeated in both pattern/texture, not too sure if this is correct, but I need to sort this out as it's the same tile being used throughout the House and Alfresco. Link to comment Share on other sites More sharing options...
Chrisb222 Posted March 6, 2024 Share Posted March 6, 2024 5 hours ago, NeilofOZ said: The config. of this image is based on 600 x 600 tile and repeated in both pattern/texture No it's not. As Dustin said, you have the TEXTURE set to 0 x 0. Change it to 600 x 600 and check your results: Also, your PATTERN settings need changed. You can't get an offset design from the single square TEXTURE image you're using. So if you want the TEXTURE and PATTERN to match, you need to change the PATTERN settings to 600 x 600 with ZERO offset. Or find another image for the TEXTURE which has a 1/2 offset. Link to comment Share on other sites More sharing options...
NeilofOZ Posted March 7, 2024 Author Share Posted March 7, 2024 Chris, I have tried many configs, but hadn't done the Zero Pattern, there is no Zero pattern, only No Pattern, tried this and nothing has changed, final image still the same as my last Pic. Just a thought, I have the tile positioned on top of a slab I created, thinking I needed to have a base to add tiling to, would this make any difference?? Link to comment Share on other sites More sharing options...
NeilofOZ Posted March 8, 2024 Author Share Posted March 8, 2024 Gentlemen, heard nothing for a while but still no answers to my initial question, I have:- 1.Followed Chris's comments regarding the tile size and Zero Pattern. 2.Followed Rob's comment and tried his and other similar configs. 3.Followed Dustin's comment and nothing changed. 4.Downloaded Substance Player as per Eric's suggestion, downloaded main program, couldn't add The Tile Builder as it kept coming up as can't recognize, gave up after about a dozen tries, In every case it appears that the selected Texure fills the slab area without any joints, this just expands the texure to the slab and gives a distorted image totally to the original material, surely this issue can't be that complex?? REGARDS, Neil Link to comment Share on other sites More sharing options...
NeilofOZ Posted March 8, 2024 Author Share Posted March 8, 2024 Eric, thanks for getting back to me, tried to send CA Plan but file too large, how do i get around this?? Link to comment Share on other sites More sharing options...
Mark3D Posted March 8, 2024 Share Posted March 8, 2024 Try and zip or compress the plan or put it on dropbox, google drive or one drive and send them a link, another option is add the material to library from plan materials then export it to your desktop upload it to the forum or send to chief support Link to comment Share on other sites More sharing options...
ericepv Posted March 8, 2024 Share Posted March 8, 2024 6 hours ago, NeilofOZ said: Gentlemen, heard nothing for a while but still no answers to my initial question, I have:- 1.Followed Chris's comments regarding the tile size and Zero Pattern. 2.Followed Rob's comment and tried his and other similar configs. 3.Followed Dustin's comment and nothing changed. 4.Downloaded Substance Player as per Eric's suggestion, downloaded main program, couldn't add The Tile Builder as it kept coming up as can't recognize, gave up after about a dozen tries, In every case it appears that the selected Texure fills the slab area without any joints, this just expands the texure to the slab and gives a distorted image totally to the original material, surely this issue can't be that complex?? REGARDS, Neil Neil: As you are having trouble adding Tile Builder, give this site a try https://www.stonecurators.com/stone-designer/ (it was buried at the bottom of my earlier post so perhaps you missed it). It's easy to use (nothing to download), provides plenty of options and produces impressive results. Eric Link to comment Share on other sites More sharing options...
NeilofOZ Posted March 9, 2024 Author Share Posted March 9, 2024 Eric, see attached material from my library as requested, fingers crossed you can sort this one out for me. Robusta Light Grey.calibz Link to comment Share on other sites More sharing options...
Mark3D Posted March 9, 2024 Share Posted March 9, 2024 The image you have found is not any good bad lighting and has no grout it will not work you need a image with even lighting and has half grout joint around it edges. Link to comment Share on other sites More sharing options...
Mark3D Posted March 9, 2024 Share Posted March 9, 2024 See if that is good enough Link to comment Share on other sites More sharing options...
NeilofOZ Posted March 10, 2024 Author Share Posted March 10, 2024 Mark, a beautiful sight to my eyes, was this done via Substance Player, worked like a treat, if only I could do likewise with the Face Bricks, but it appears the original image wasn't suitable. Link to comment Share on other sites More sharing options...
Mark3D Posted March 10, 2024 Share Posted March 10, 2024 28 minutes ago, NeilofOZ said: Mark, a beautiful sight to my eyes, was this done via Substance Player, worked like a treat, if only I could do likewise with the Face Bricks, but it appears the original image wasn't suitable. Not substance i did it with a program called genetica as substance could not fix the bad lighting, Genetica has slider to try and equalize the lighting 1 Link to comment Share on other sites More sharing options...
Mark3D Posted March 10, 2024 Share Posted March 10, 2024 one more Link to comment Share on other sites More sharing options...
