cbucks Posted January 20, 2024 Share Posted January 20, 2024 Sorry new b question how do I show a sloped terrain in a side clip elevation view? Link to comment Share on other sites More sharing options...
ericepv Posted January 20, 2024 Share Posted January 20, 2024 38 minutes ago, cbucks said: Sorry new b question how do I show a sloped terrain in a side clip elevation view? Use a CrossSection/Elevation camera and make sure the Terrain Permiter layer is turned on. Link to comment Share on other sites More sharing options...
GeneDavis Posted January 20, 2024 Share Posted January 20, 2024 I leave terrain off in the layerset, and CAD for the terrain, the polyline (all white lines) has a transparent solid fill with light gray color, the top line of the p'line has a CAD line overlay at a line weight that makes sense. You can get fancy and do a 45 deg. line fill in that p'line to give the foundation a dashed line look, but I was lazy on this one. The reason I turn off the terrain (different from what Eric suggests above) is that often there is too much going on and one gets multiple lines. This simple approach works for me. 1 Link to comment Share on other sites More sharing options...
imodel Posted January 21, 2024 Share Posted January 21, 2024 I agree with Gene except I would use a non transparent fill. Unless you are required to show the foundation in your jurisdiction. Many do not require a foundation to be shown in elevation. Link to comment Share on other sites More sharing options...
nicknz Posted January 23, 2024 Share Posted January 23, 2024 I do the same as Gene plus use a cross hatch fill so the below ground shows hatched/dotted lined. Link to comment Share on other sites More sharing options...
SHCanada2 Posted January 23, 2024 Share Posted January 23, 2024 i try and make it work first by putting a terrain region at the front (all the way across the terrain(actually beyond the terrain on both sides), and then one at back ( 6 ft lower), all the way across the property. If the drop like Gene has is the only thing you need, then it works. Where it doesn't work is where corners of the property are different elevations, or if you have wing walls with a lower elevation region between them, or different elevation points(as opposed to just two regions) CA has a good video of it Link to comment Share on other sites More sharing options...
