DRyeHD Posted August 24, 2023 Share Posted August 24, 2023 Most of the time, on a 2-story home, when I do an elevation view the materials overlap (see attached). Do I have a setting wrong somewhere? What would be causing this? I've learned not to adjust autogenerated walls, so I'm trying to find the right way to fix this. Any input is appreciated. Link to comment Share on other sites More sharing options...
GeneDavis Posted August 24, 2023 Share Posted August 24, 2023 Siding always covers floor framing for whatever floor or floors you view in an elevation. If you are getting some double line at your ceiling / floor junctures, you are doing something wrong. I opened a new plan, did walls for a two floor box house with board and batten siding, clicked to get auto storypole, and look what I got. Link to comment Share on other sites More sharing options...
DRyeHD Posted August 24, 2023 Author Share Posted August 24, 2023 3 minutes ago, GeneDavis said: Siding always covers floor framing for whatever floor or floors you view in an elevation. If you are getting some double line at your ceiling / floor junctures, you are doing something wrong. I opened a new plan, did walls for a two floor box house with board and batten siding, clicked to get auto storypole, and look what I got. I guess I need to go back and check some things. My overlap is 1 1/4" which is the thickness of my 2nd floor subfloor. I added the subfloor after I created the elevation section view. Do you think this would create the double line? Link to comment Share on other sites More sharing options...
DRyeHD Posted August 24, 2023 Author Share Posted August 24, 2023 @GeneDavis here's a screeshot of the structure dbx. Do you see any wrong settings. I'll be glad to post the .pln file if you don't mind taking a look. This has been an issue for a while. Link to comment Share on other sites More sharing options...
robdyck Posted August 24, 2023 Share Posted August 24, 2023 1 hour ago, DRyeHD said: I'll be glad to post the .pln file if you don't mind taking a look This would be best. I can take a look as well... Link to comment Share on other sites More sharing options...
GeneDavis Posted August 24, 2023 Share Posted August 24, 2023 I just added a second subfloor layer to my floor 2 floor structure. Formerly it was 9.5 inch joist with 3/4 subfloor total 10-1/4. The elevation now shows 11 inches between and there is no pair of lines there 3/4 apart. Why would you add a subfloor atop a subfloor? Link to comment Share on other sites More sharing options...
DRyeHD Posted August 24, 2023 Author Share Posted August 24, 2023 @robdyck and @GeneDavisI've attached the .pln file. I didn't describe the subfloor very well. My 2nd floor is an 18" truss. I noticed that it didn't have a subfloor so I added one (1 1/4" plywood). Medlyn.zip Link to comment Share on other sites More sharing options...
Solution robdyck Posted August 24, 2023 Solution Share Posted August 24, 2023 Select the lower wall, Structure Tab, Click Default wall top height Link to comment Share on other sites More sharing options...
TeaTime Posted August 24, 2023 Share Posted August 24, 2023 Better yet: Edit, Reset to Defaults, All Floors, and check both Wall top and Bottom heights. 1 Link to comment Share on other sites More sharing options...
robdyck Posted August 24, 2023 Share Posted August 24, 2023 Hey Damon, you also haven't corrected the thickness of the flooring in the Kitchen. Open to Room Spec for the Kitchen, Define the floor finish to use the default, and make sure the default is checked in the structure tab. Nice looking place, by the way! Link to comment Share on other sites More sharing options...
DRyeHD Posted August 25, 2023 Author Share Posted August 25, 2023 16 hours ago, robdyck said: Select the lower wall, Structure Tab, Click Default wall top height @robdyck it seems that many of my issues are easy fixes. I've set up a new construction template but it always seems like I mess it up somehow. Just like the kitchen floor - I've tried to go room by room and set the defaults but I obviously missed that. I keep a running list of update items but I never seem to get it all done. I don't know about your area, but this type of house is really popular around here these days. I'm glad you like it...nice PBR. @TeaTime I'll keep your method in mind when I need a more drastic reset. This plan has 9', 10' and open ceilings so I didn't want to reset the whole floor. Anyway, thanks for both of your input. I'll be keeping these items in mind when this happens again...which I'm sure it will! Have a great weekend. 1 Link to comment Share on other sites More sharing options...
DBCooper Posted August 25, 2023 Share Posted August 25, 2023 Quote This plan has 9', 10' and open ceilings so I didn't want to reset the whole floor. If you only reset the "wall top heights" and "wall bottom heights" it won't change any of your floor or ceiling heights. Basically, it will only reset your walls back to default heights when you have manually moved the wall top/bottom up/down (which is something you usually don't need to do to change your ceiling heights). Link to comment Share on other sites More sharing options...
TeaTime Posted August 25, 2023 Share Posted August 25, 2023 1 hour ago, DBCooper said: you have manually moved the wall top/bottom up/down (which is something you usually don't need to do to change your ceiling heights). ^^ exactly this - avoid yankin your walls around in camera views and you'll save yourself a lot of headaches. Generally speaking, the program knows how to do walls better than we do. Link to comment Share on other sites More sharing options...
DRyeHD Posted August 25, 2023 Author Share Posted August 25, 2023 8 hours ago, DBCooper said: If you only reset the "wall top heights" and "wall bottom heights" it won't change any of your floor or ceiling heights. Basically, it will only reset your walls back to default heights when you have manually moved the wall top/bottom up/down (which is something you usually don't need to do to change your ceiling heights). That's good to know. Thanks! Link to comment Share on other sites More sharing options...
DRyeHD Posted August 25, 2023 Author Share Posted August 25, 2023 7 hours ago, TeaTime said: ^^ exactly this - avoid yankin your walls around in camera views and you'll save yourself a lot of headaches. Generally speaking, the program knows how to do walls better than we do. I'm learning that...the hard way. I just still don't know all the ins and outs of adjusting things the right way. You all have been helpful though. Link to comment Share on other sites More sharing options...
