SHCanada2 Posted April 28, 2023 Share Posted April 28, 2023 so I saw this yesterday and then redrew the deck to fix it, but now it has happened again today. I was resizing the joists in the deck from 2x10 to 2x8, and now it looks like this, with the joist protruding through the deck boards. Anyone else seen this? xsec shows the rim board dropped properly I thought maybe it had to do with this setting, but even if it does, how does one "fix it" now, as changing it doesnt seem to do anything even if I resize now to 2x6 changed to 2x6 and now it is worse I tried rebuilding all framing, no luck I could just lower them all manually, but really there must be a way to get them to move, without having to redraw the deck Link to comment Share on other sites More sharing options...
DBCooper Posted April 28, 2023 Share Posted April 28, 2023 Quote I tried rebuilding all framing, no luck I don't think deck framing rebuilds with any of the other framing. You could try rebuilding the deck framing manually. Just select the deck room and look for the deck framing button. Not sure why it wouldn't rebuild automatically though. May want to report to Chief. Link to comment Share on other sites More sharing options...
Kbird1 Posted April 28, 2023 Share Posted April 28, 2023 1 hour ago, SHCanada2 said: tried rebuilding all framing, no luck Is the retain framing option checked instead of Clear ( and auto frame on ) Link to comment Share on other sites More sharing options...
SHCanada2 Posted April 28, 2023 Author Share Posted April 28, 2023 1 hour ago, Kbird1 said: Is the retain framing option checked instead of Clear ( and auto frame on ) no ...see second screenshot (which looks like it is part of the first) Link to comment Share on other sites More sharing options...
SHCanada2 Posted April 28, 2023 Author Share Posted April 28, 2023 3 hours ago, DBCooper said: Just select the deck room and look for the deck framing button. unfortunateely it did not work. i think maybe it is because I have the deck next to a covered deck (both are decks). And the covered deck is 2x10 Link to comment Share on other sites More sharing options...
SHCanada2 Posted April 28, 2023 Author Share Posted April 28, 2023 even if I pull back a deck wailing wall and change the size, it is keeping the joists in the same position. if I lower the room floor in abolsute elevation, they still jsut stay there. I think CA thinks I have "retain deck framing" on, even thought it is off....but odd it is only the joists if I delete the the entire deck room, they are still there: Link to comment Share on other sites More sharing options...
SHCanada2 Posted April 28, 2023 Author Share Posted April 28, 2023 i gave up, deleted the joists and redrew Link to comment Share on other sites More sharing options...
Chrisb222 Posted April 28, 2023 Share Posted April 28, 2023 26 minutes ago, SHCanada2 said: i gave up, deleted the joists and redrew I would send that in. It seems like "unintended functionality." * (* Yeah, that's a thing, according to TS. ) Link to comment Share on other sites More sharing options...
ProPlan_2011 Posted April 29, 2023 Share Posted April 29, 2023 2 hours ago, SHCanada2 said: i gave up, deleted the joists and redrew That behavior has been a mystery for me for quite a while. I often end up with uninvited pieces of framing even though auto framing is on, especially with roofing. I've learned to manually delete those and force a rebuild after. Link to comment Share on other sites More sharing options...
