marlem2000 Posted December 12, 2022 Share Posted December 12, 2022 Hi there! I've been trying to find out a way to make holes in walls but I didn't find any solution yet. I tryed to create a polyline and, then, convert it into a slab with footing but I could't rotate the solid piece to put it in the wall. I guess the right method is very different. My plan is to build something similar to a forniture in the wall. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted December 12, 2022 Share Posted December 12, 2022 That just looks like an Opening to me. See if maybe a Doorway or Pass-Through does what you're looking for. Link to comment Share on other sites More sharing options...
marlem2000 Posted December 12, 2022 Author Share Posted December 12, 2022 Hi, Michael! I hadn't though about the doorway. I've just made a try and, maybe, it could work. I'm getting some problems to fit the forniture to the moldings but I think I can manage. I suppose there are other better methods to make a hole in a wall but I'll keep on studying. There are too many options in this programme! Link to comment Share on other sites More sharing options...
ProPlan_2011 Posted December 12, 2022 Share Posted December 12, 2022 Have you thought of a wall niche? Your 2nd picture suggests a wall quite thick. Then you could insert a cabinet into the niche. 1 Link to comment Share on other sites More sharing options...
ericepv Posted December 12, 2022 Share Posted December 12, 2022 I usually use a pass-thru (under the windows tab) for something like this. You can delete the sill, casing and frame. Link to comment Share on other sites More sharing options...
marlem2000 Posted December 13, 2022 Author Share Posted December 13, 2022 I have made several tryes with the pass-thru and the wall niche. Both are interesting; maybe the wall niche is more complete but a bit messy for me too. Is there a way to change the molding on the top of the niche in order to make it different from the rest one? Link to comment Share on other sites More sharing options...
MPDesign Posted December 13, 2022 Share Posted December 13, 2022 yes, it is called the "Lintel" Link to comment Share on other sites More sharing options...
marlem2000 Posted December 13, 2022 Author Share Posted December 13, 2022 (edited) One more time, this is a clear proof that I don't know the right names about interiors and architecture, specially in English! Tons of thanks again, Michael! I think now I have managed to create what I want. It's not totally perfect but I'll keep on improving. Thanks again! Edited December 13, 2022 by marlem2000 My bad English Link to comment Share on other sites More sharing options...
MarkMc Posted December 13, 2022 Share Posted December 13, 2022 Far right were done as fixtures interior insert into wall- Made with 3 cabinets to get the curved back in the photo supplied. Not simple Left is just a straight cabinet. Did that as a fixed door which makes the casing easier to control. To me using cabinets for the original is also easier to control. Link to comment Share on other sites More sharing options...
