Argy67 Posted October 3, 2022 Share Posted October 3, 2022 In an attempt to simplify my decks, I blocked an Azek 4x4 post, cap and a post skirt. I turned the block into a symbol, but didn't get the result I was looking for. Looking for a way to be able to create a custom newel that can be selected as a newel in the dbx. Help!! Link to comment Share on other sites More sharing options...
Solution robdyck Posted October 3, 2022 Solution Share Posted October 3, 2022 You've followed the correct steps, although you don't need to make a block of those items, you simply need to select all 3 and then convert to symbol (Millwork category). Of, course the cap and skirt must be set at the correct heights relative to the post before executing that function. You may need to post an image of the problem and describe what wasn't working for you. 1 Link to comment Share on other sites More sharing options...
DBCooper Posted October 3, 2022 Share Posted October 3, 2022 Quote I turned the block into a symbol, but didn't get the result I was looking for. Why not? What were you expecting and what did you get? This article might help: https://www.chiefarchitect.com/support/article/KB-02893/creating-custom-balusters-and-railing-panels.html Link to comment Share on other sites More sharing options...
GeneDavis Posted October 3, 2022 Share Posted October 3, 2022 What's an Azek post skirt? Is it something continuous along the deck fascia? Chief won't generate that with a newel. I played with Chief symbol-making for newels and balusters, about 5 or 6 releases ago. Maybe more. Took a Sketchup model of a Winchester model 94 30-30 carbine, imported it in as a millwork item, and made some fancy balustrades. Did it also with a Donald Duck model. Blew out my poly counts, but it was cool. Link to comment Share on other sites More sharing options...
joey_martin Posted October 3, 2022 Share Posted October 3, 2022 7 minutes ago, GeneDavis said: What's an Azek post skirt? I think he is trying to make one of these... The pieces are in the AZEK library but you have to assemble them and make a symbol to use them. The base he is calling a skirt. @Argy67 here is one I keep in my library... AZEK Deck Post w_Cap & Base.calibz 1 Link to comment Share on other sites More sharing options...
robdyck Posted October 3, 2022 Share Posted October 3, 2022 Joey just beat me to it. It's faster to make one than to talk about it. Azek 4x4 Post.calibz Link to comment Share on other sites More sharing options...
GeneDavis Posted October 3, 2022 Share Posted October 3, 2022 That's a very pretty skirt! Link to comment Share on other sites More sharing options...
Alaskan_Son Posted October 3, 2022 Share Posted October 3, 2022 58 minutes ago, solver said: Well what result did you get? What result did you expect? I'm all but certain that the OP simply converted to the wrong symbol type based on the last sentence in the post... 11 hours ago, Argy67 said: Looking for a way to be able to create a custom newel that can be selected as a newel in the dbx. If I were a betting man, I'd bet that Robert already pointed out the most likely culprit... 3 hours ago, robdyck said: convert to symbol (Millwork category) Link to comment Share on other sites More sharing options...
Argy67 Posted October 11, 2022 Author Share Posted October 11, 2022 Thank you everyone. Appreciate all of the help. Link to comment Share on other sites More sharing options...
