door details
Hammer7
Are you using a fixed door or a window for the side lite?  I find that the fixed door generally behaves better than a window.
Either way, I don't think you can control the threshold or extra piece of jamb separate from the trim material.
22 hours ago, Hammer7 said:
Is there a way to get both of the thresholds to appear the same and be aluminum finish separate from door colors and the in between jamb to be white?
If it is something that is really important to render correctly you could convert to a symbol and work with the individual surfaces to apply your own materials.  Just a lot of tedious work but completely possible.
