creatrix Posted July 18, 2022 Share Posted July 18, 2022 Anyone up and able to give me some advice on getting this Quartzite imported material(second screen shot) to look more like the slab (first screen shot) I've taken it from? Third screenshot is my Library material. Link to comment Share on other sites More sharing options...
ericepv Posted July 18, 2022 Share Posted July 18, 2022 Have you placed any additional light sources? Also, what are the settings for your material properties? Link to comment Share on other sites More sharing options...
Joe_Carrick Posted July 18, 2022 Share Posted July 18, 2022 Try adjusting the color of the material to a lighter shade of grey and make sure it's set to "Blend with Texture" Link to comment Share on other sites More sharing options...
MarkMc Posted July 18, 2022 Share Posted July 18, 2022 11 hours ago, creatrix said: look more like the slab Will get richer colors if you adjust the brightness in a photo editor than using blend. two version below, image files attached. Forgot as these have lights overhead (as aluded to by Eric) Quartzite2.zip Link to comment Share on other sites More sharing options...
Renerabbitt Posted July 18, 2022 Share Posted July 18, 2022 I would say, considering that the slab was taken with a professional light setup for marketing purposes, that chiefs representations is probably pretty accurate. Otherwise what other's have said will work Link to comment Share on other sites More sharing options...
creatrix Posted July 18, 2022 Author Share Posted July 18, 2022 It is so awesome that y'all are out there and willing to help— my gratitude extends! I do not have any included light sources and know that's an issue. Mark, thank you so much for the zip! I'll work with them and attempt adding a light source. I thought I was fired by these clients and then they call with an emergency — life of a consultant!! Link to comment Share on other sites More sharing options...
ericepv Posted July 18, 2022 Share Posted July 18, 2022 Proper lighting and material properties are key to a good rendering. Keep experimenting and you'll eventually land on the right combination. Link to comment Share on other sites More sharing options...
johnny Posted July 18, 2022 Share Posted July 18, 2022 The variation in light/dark your seeing in Chief may be the same variations that could occur in real life without looking right at the material with camera lighting (in your 1st pic). To me they look identical....again, outside the variation you'd expect to see dependent on lighting. If you do artificially lighten the material, and its going to be that sensitive to the client, you might actually represent the wrong tone once its placed in the actual kitchen. Link to comment Share on other sites More sharing options...
