Pavers
Dennis_Gavin
Just a recommend but 3d textures like pavers look amazing if you create a bump-map.
pavement11_close_disp.jpg?1327594806
This was taken from a place you can buy 3d textures - http://www.creativecrash.com/marketplace/3d-textures/c/paver-blocks-11-high-res-set
Here are some free paver downloads with bump-map, but more limited selection -
http://www.rendertextures.com/category/concrete/pavers/
FYI that free location has a lot of very good textures for quick projects.
Look under tile > patterned > random in the core library materials. If you adjust the scale and 'blend with color' on some of these, they look like a random paver pattern on the top. I hide the sides with plants. I've also used the Dal Tile > Natural Stone > Champaign Gold, 1x1 with scale adjusted to 48" and "blend with color" and those turned out great as square pavers.
  • 1 year later...
yeah, those could work. However - what I thought I might need these for turns out to not be the case..
Thanks.
Im with you Dennis.  I do a lot of pavers for clients and I just can't get the right ones.  I would be nice if we had some CalSTone Pavers in our library.
