wazzubrad Posted June 5, 2022 Share Posted June 5, 2022 I can't seem to find which layer or setting that pertains to the "3D Exterior Elevation" which appears on a schedule? For example; the picture of the doors on this door schedule have a line weight setting that isn't going to work. Any ideas how to change this? Link to comment Share on other sites More sharing options...
Gawdzira Posted June 5, 2022 Share Posted June 5, 2022 Are you able to reproduce this in other files? I can not get that look. Link to comment Share on other sites More sharing options...
Kbird1 Posted June 6, 2022 Share Posted June 6, 2022 You might need to share the Plan , or an example at least ... I have not ever seen that. If you fixed it please post back with the Solution, thanks. M. Link to comment Share on other sites More sharing options...
glennw Posted June 6, 2022 Share Posted June 6, 2022 How and where did you create the door schedule? 1 Link to comment Share on other sites More sharing options...
wazzubrad Posted June 6, 2022 Author Share Posted June 6, 2022 12 hours ago, glennw said: How and where did you create the door schedule? I created the door schedule within Cad Detail Management in my Plan file. I do setup custom line weights via Print -> Drawing Sheet Setup (snip below) and was going through editing my new X14 Template when I found this issue. Here is a link to my plan file; http://gofile.me/5m788/kaxgaD8Qj Link to comment Share on other sites More sharing options...
rgardner Posted June 6, 2022 Share Posted June 6, 2022 18 minutes ago, wazzubrad said: I created the door schedule within Cad Detail Management in my Plan file. I do setup custom line weights via Print -> Drawing Sheet Setup (snip below) and was going through editing my new X14 Template when I found this issue. Here is a link to my plan file; http://gofile.me/5m788/kaxgaD8Qj That Cad detail is not in sync with the rest of your plan most likely. By chance is the rest of the plan 1:200 MM and not in? OOB is 1:100. I personally use 1:150 for slightly better control but mm not inches. Link to comment Share on other sites More sharing options...
wazzubrad Posted June 6, 2022 Author Share Posted June 6, 2022 43 minutes ago, rgardner said: That Cad detail is not in sync with the rest of your plan most likely. By chance is the rest of the plan 1:200 MM and not in? OOB is 1:100. I personally use 1:150 for slightly better control but mm not inches. As far as I know the Line Weights are set in Print -> Drawing Sheet Setup, so I am assuming the "rest of the plan" is set per the snip. Is there somewhere else I should look? I have setup the line weights this way per a suggestion I read prior in the forums and am trialing the look. I had to go through and adjust quite a few layers with new line weight settings which it looks like it's working well so far. Link to comment Share on other sites More sharing options...
wazzubrad Posted June 6, 2022 Author Share Posted June 6, 2022 Ryan, I set the plan and layout files to 1:200MM and it cleared up the issue in the 3D Exterior Elevation. But this has created a new issue for me as would need adjust all of the line weight values on the layers I changed previously. I will need to decide which setting is preferable for me. Link to comment Share on other sites More sharing options...
rgardner Posted June 6, 2022 Share Posted June 6, 2022 5 minutes ago, wazzubrad said: Ryan, I set the plan and layout files to 1:200MM and it cleared up the issue in the 3D Exterior Elevation. But this has created a new issue for me as would need adjust all of the line weight values on the layers I changed previously. I will need to decide which setting is preferable for me. 1:200 inches is going to be difficult to have much finite control on the lines. OOB is 1:100mm and I usually stay fairly close to the standard oob line settings but change it to 1:150mm so it is a little finer control. Then I adjust a few line settings. Doing a full set of construction documents while doing it will really help you to dial them in. Then use the save as a template tool to save a copy for a new template. Link to comment Share on other sites More sharing options...
wazzubrad Posted June 6, 2022 Author Share Posted June 6, 2022 Thanks Ryan, I will move forward with that suggestion. Link to comment Share on other sites More sharing options...
Solution wazzubrad Posted June 6, 2022 Author Solution Share Posted June 6, 2022 For anyone who runs into this same problem that I created, I realized that when editing a Cad Detail, you can also set the Line Weight Options for Cad Details in the Drawing Sheet Setup dialog under File->Print->Drawing Sheet Setup. When I changed the Line Weights there to match my Plan and Layout files, it fixed the Line Weights on my schedules and everything looks correct now. 1 Link to comment Share on other sites More sharing options...
