creatrix Posted May 2, 2022 Share Posted May 2, 2022 Would someone tell me where to find pipe like shown in my screenshot? I'm sure it's in some catalog but haven't found it or any support info on where it might be. Link to comment Share on other sites More sharing options...
BrownTiger Posted May 2, 2022 Share Posted May 2, 2022 Take the Dock Support pipe, change material to white, hit the chair, change width from 2 1/4 -> 6", rotate 90. Link to comment Share on other sites More sharing options...
rgardner Posted May 2, 2022 Share Posted May 2, 2022 Molding line or polyline…? Link to comment Share on other sites More sharing options...
Joe_Carrick Posted May 3, 2022 Share Posted May 3, 2022 IAE, That's being used as an exhaust vent from the Tankless Water Heater. It isn't a Water Supply Pipe. Is there really a reason you need to include it it the model? 1 Link to comment Share on other sites More sharing options...
Chopsaw Posted May 3, 2022 Share Posted May 3, 2022 13 minutes ago, Joe_Carrick said: IAE, That's being used as an exhaust vent from the Tankless Water Heater. It isn't a Water Supply Pipe. Is there really a reason you need to include it it the model? Maybe just so there is something to put some dimensions on so that the hole does not get cut in the wrong place next time. See photo above. Link to comment Share on other sites More sharing options...
creatrix Posted May 3, 2022 Author Share Posted May 3, 2022 Thanks Joe, I woke up this morning thinking it's an exhaust and not supply. Yes I want to put it in because I'm designing a panel to cover it. Link to comment Share on other sites More sharing options...
Chopsaw Posted May 3, 2022 Share Posted May 3, 2022 25 minutes ago, creatrix said: I woke up this morning thinking it's an exhaust and not supply. Yes the copper one that comes up from the bottom right will be the supply. Link to comment Share on other sites More sharing options...
creatrix Posted May 3, 2022 Author Share Posted May 3, 2022 Brown Tiger, I'll try your suggestion — thanks so very much! Link to comment Share on other sites More sharing options...
Solution Dermot Posted May 3, 2022 Solution Share Posted May 3, 2022 I would probably just use a 3D molding polyline (as suggested by Ryan) with a round molding profile set to the size of the pipe. I think it will give you a much more realistic model and it will allow you to more easily do things like accurately design the vent with the proper slope to meet code. Plus learning how to use the 3D molding polyline might come in very handy for other situations, like with other HVAC or plumbing. Link to comment Share on other sites More sharing options...
