KnotSquare Posted March 11, 2022 Share Posted March 11, 2022 This is a simple garage design where I had a stem wall that was above the slab. I moved down in the plan view to the slab level and redesigned it to have the stem stop at the top of the slab and rebuild my framing. Now the section view shows the bottom cord raised above the top plate like a collar-tie. It should be common trusses as the perspective framing overview correctly shows. I cannot determine the cause of the difference and fear it will affect my Material List. Ideas? Mark Farrar mark@knottystudios.com Knot Square Design, LLC Butte, Montana Chief Architect Premier X13 Bell Garage w-o Splash Wall.plan Link to comment Share on other sites More sharing options...
Richard_Morrison Posted March 11, 2022 Share Posted March 11, 2022 1) Change room height to 9' studs. 2) Change roof structure to match trusses. 3) Turn on truss layer in section view. Link to comment Share on other sites More sharing options...
KnotSquare Posted March 11, 2022 Author Share Posted March 11, 2022 Richard, This is to be a 10' pre-cut stud build. Looking at 'sovler' next, but thank you. Mark Link to comment Share on other sites More sharing options...
KnotSquare Posted March 11, 2022 Author Share Posted March 11, 2022 Solver, I did the first step and thank you, I did not realize that the specifications below were set for each layer. This may save me in other situations as well. I just saw that you followed up and may answer why the profile still shows that the wall is dogeared. Mark Link to comment Share on other sites More sharing options...
KnotSquare Posted March 11, 2022 Author Share Posted March 11, 2022 Solver, Unsure if this is the answer. They were correct in the Perspective Framing Overview and when I manually raised them 12" and changed that siding criteria, I got the attached result. My Room Specifications appear correct. Is there a specific way I should have raised them? I prefer getting the settings correct verses manually changing anything. Mark Link to comment Share on other sites More sharing options...
KnotSquare Posted March 11, 2022 Author Share Posted March 11, 2022 Makes perfect sense, but is there a REAL way to fix it correctly at this stage? It appears that only the gable wall is incorrect in this view. I ask as I am in the midst of (3) large projects that have rooms and wall heights that very throughout the design. I also have a project I have almost reached contract on that will not only have varying plate heights, but is to be designed to Passive House standards and the main section through the middle of the house is a true mortise and tenon timber frame. I am using Chief for the design work to produce a Material List, but create my construction documents in AutoCAD LT. Of course I use Chief to design with my clients to help them visualize the final product. Link to comment Share on other sites More sharing options...
KnotSquare Posted March 11, 2022 Author Share Posted March 11, 2022 I updated my profile settings. Hopefully that will change once this thread is done. Link to comment Share on other sites More sharing options...
KnotSquare Posted March 11, 2022 Author Share Posted March 11, 2022 When I opened edit it was correct. It is not updating, at least in this thread. I hit Save again. I will see when I submit this reply. Link to comment Share on other sites More sharing options...
KnotSquare Posted March 11, 2022 Author Share Posted March 11, 2022 When I set this up I used Match Trusses, but I am having trouble locating that setting again. Where was that located? This is an easy rebuild of the entire project, but I am seeking knowledge for when I have to deal with situations such as this in my larger models. Link to comment Share on other sites More sharing options...
KnotSquare Posted March 11, 2022 Author Share Posted March 11, 2022 I selected the roof planes and opened them. It stated that the Top Plate was at 109 1/8". Not being able to change that to the known 121 1/8" I locked the Pitch and added 12" to another value and walla! Fixed. Link to comment Share on other sites More sharing options...
KnotSquare Posted March 11, 2022 Author Share Posted March 11, 2022 Digging the Vector View for framing. Great tip. I can go back to a previously saved version and do just what you demonstrated, but not on this model as I have deleted the entire roof and rebuilt it. I realize you are likely helping others, but if you have a moment, here are the settings I have and I do not know why I do not get trusses instead of 2x4 rafters. Model upload is failing. Will try right behind this. Bell Garage w-o Splash Wall.plan Link to comment Share on other sites More sharing options...
KnotSquare Posted March 11, 2022 Author Share Posted March 11, 2022 Model upload. I need to write this tip in my OneNote files. Having a heck of a time finding this information again. I found it the first go around. Bell Garage w-o Splash Wall.plan Link to comment Share on other sites More sharing options...
SHCanada2 Posted March 11, 2022 Share Posted March 11, 2022 you have to build trusses. there are none there, see solver's video to check for them An ugly way....:Turn your all layers on set. You will see the rafters. Click Build-Framing-Roof Truss draw from top to bottom on right most rafter. then select the truss and multiple copy to the left.. Delete ridge rafter There is a video on trusses by CA one item from my "one note" on trusses. you may need to rebuild the truss after altering the room or roof plane,do this by selecting the truss, open up the dialog, check Force truss rebuild Link to comment Share on other sites More sharing options...
KnotSquare Posted March 11, 2022 Author Share Posted March 11, 2022 Almost perfect. The end truss does not become a drop truss even if I designate it as such and the outlookers did not reach back to the next truss. I can likely stretch the outlookers if I turn on that layer in plan view, but I do not know what to do about the drop truss. This should not affect my Materials List and the truss company will make the correction, just wondering if I am still missing something. Great solution Jason. Thank you for helping me recall where the build truss was located. Link to comment Share on other sites More sharing options...
MPDesign Posted March 11, 2022 Share Posted March 11, 2022 you need to "force truss rebuild" to get it to update the framing. Link to comment Share on other sites More sharing options...
HumbleChief Posted March 11, 2022 Share Posted March 11, 2022 10 hours ago, solver said: Tip: If you set your defaults, ceiling height for example, before drawing, then roofs (and trusses), both auto and manual will be at the correct height. This advice will save you a LOT of pain in the future with building any structure in Chief. Link to comment Share on other sites More sharing options...
rgardner Posted March 11, 2022 Share Posted March 11, 2022 7 hours ago, KnotSquare said: The end truss does not become a drop truss even if I designate it as such and the outlookers did not reach back to the next truss. I can likely stretch the outlookers if I turn on that layer in plan view, but I do not know what to do about the drop truss. Select your two end trusses, open them, change them to reduced gable trusses, rebuild them. Once done with placing your trusses either select both roof planes and hit the frame selected to put in the rest of the framing manually. You most likely will have to clean up a little bit of framing but as long as your end trusses are reduce gable (and I suggest selecting as end trusses as well so it gives the backing for siding), the "outlookers" will build properly. Link to comment Share on other sites More sharing options...
