ICF brick ledges
NorthBayChief
2 hours ago, NorthBayChief said:
Thank you so much for the answer. I was hoping it wouldn't be that much work. Surprised they would put ICF in their foundation standards, but only do half a job.
I'm not sure I'd call the omission of something as rare as an ICF brick ledge a problem. I've designed and built an awful lot of ICF structures using every brand and size and form profile imaginable and it is much easier and simpler to model a brick ledge form using a molding polyline than it would be through any configuration of dialog boxes. There simply are too many types and they are rarely used. If you use them in your drafting projects regularly, then you should have library of items ready to help you model this condition.
It should take about 2-3 minutes to have that modeled accurately (the first time), using one of a variety of methods. After that, it should (or at least could) be almost automatic.
