dbkb0227 Posted January 20, 2022 Share Posted January 20, 2022 Hello all! Attached is a pic of a set of stairs that a client is interested in doing in their new home. You see how the back of the stairs has a vertical riser as well? Is there a way to create this in Chief Architect? The only way I can think of is doing is with individual landings stacked on top of each other. Thanks in advance for all the help! Link to comment Share on other sites More sharing options...
robdyck Posted January 20, 2022 Share Posted January 20, 2022 If you want separate tread / riser material like in your picture, then you will need to use landings. If you're ok with 1 material, then it can be done by using no stringers, tread overhang of about 18", and tread thickness equal to the unit rise. That would get you pretty close. Link to comment Share on other sites More sharing options...
mtldesigns Posted January 20, 2022 Share Posted January 20, 2022 Pretty cool stairs.. IMO I guess it "overlaps" for structural reasons? Will be interesting to see the detail on this. Link to comment Share on other sites More sharing options...
CharlesVolz Posted January 21, 2022 Share Posted January 21, 2022 I would use landings, countertops (can have moldings attached to them), soffits (can have moldings attached to them) or just moldings by themselves, depending on the detail required, but if you want simple you could just use the stairs tool. Link to comment Share on other sites More sharing options...
joey_martin Posted January 21, 2022 Share Posted January 21, 2022 I would building those with cabinets with the countertop being the tread so that the decorative panels can be more easily added. 2 2 Link to comment Share on other sites More sharing options...
dbkb0227 Posted January 24, 2022 Author Share Posted January 24, 2022 Thanks everybody for your help!! I really appreciate it. I went with the option of using individual landings. It renders well enough for the client to visualize it in their new home. Thanks again!! Link to comment Share on other sites More sharing options...
para-CAD Posted January 24, 2022 Share Posted January 24, 2022 Building stairs using cabinets. Wow. I would have never guessed that was a thing.....ever.....without the input from those experienced on this site. Thanks! Link to comment Share on other sites More sharing options...
