Stair Design
DB-Designs
Hello all! Attached is a pic of a set of stairs that a client is interested in doing in their new home. You see how the back of the stairs has a vertical riser as well? Is there a way to create this in Chief Architect? The only way I can think of is doing is with individual landings stacked on top of each other. Thanks in advance for all the help!
If you want separate tread / riser material like in your picture, then you will need to use landings. If you're ok with 1 material, then it can be done by using no stringers, tread overhang of about 18", and tread thickness equal to the unit rise. That would get you pretty close.
