Gawdzira Posted June 18, 2021 Share Posted June 18, 2021 We are getting closer to a parametric board and batt solution but not quite yet. X13 wall with framing on the outside. Link to comment Share on other sites More sharing options...
SNestor Posted June 18, 2021 Share Posted June 18, 2021 @Gawdzira - good try though. Looks like we are still stuck using material regions for battens... Link to comment Share on other sites More sharing options...
Richard_Morrison Posted June 18, 2021 Share Posted June 18, 2021 31 minutes ago, SNestor said: @Gawdzira - good try though. Looks like we are still stuck using material regions for battens... I went through this awhile ago. I found that a backsplash works better, although I don't recall exactly why. In elevation, just draw a single tall batten and convert to a backsplash. Then, you can multiple-copy across the wall. Doors and windows will be cut out automatically, but you can adjust height individually, group select and center on a window, etc. Link to comment Share on other sites More sharing options...
Kelly_K Posted July 18, 2022 Share Posted July 18, 2022 On 6/18/2021 at 1:48 PM, Richard_Morrison said: I went through this awhile ago. I found that a backsplash works better, although I don't recall exactly why. In elevation, just draw a single tall batten and convert to a backsplash. Then, you can multiple-copy across the wall. Doors and windows will be cut out automatically, but you can adjust height individually, group select and center on a window, etc. I needed 1x6 battens on a project, and could not find anything to my satisfaction to even create such. This is a really good work around for what I needed. thanks Richard Link to comment Share on other sites More sharing options...
DRAWZILLA Posted July 21, 2022 Share Posted July 21, 2022 try an exterior framing layer for the batts, some people use that method. Link to comment Share on other sites More sharing options...
Kbird1 Posted July 21, 2022 Share Posted July 21, 2022 5 minutes ago, DRAWZILLA said: try an exterior framing layer for the batts, some people use that method. Yep , been using that method myself when needed for 4-5 yrs now Link to comment Share on other sites More sharing options...
