jkonecny Posted June 16, 2021 Share Posted June 16, 2021 I'm well overdue to upgrade to x12 or x13. Is there any problems associated with upgrading to x12 and then working on files/plans that were created in x10? X12 seems worlds ahead of x10. I have Several projects ongoing now and I fear i would have issues if i were to upgrade mid project. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted June 16, 2021 Share Posted June 16, 2021 There shouldn't be any problems. I have several projects from up to 5 versions back. Whenever I need to do additional work on one of those I just open it in the latest version, save it to my new version project folder and use that going forward. 1 Link to comment Share on other sites More sharing options...
jkonecny Posted June 16, 2021 Author Share Posted June 16, 2021 Thanks Joe! Link to comment Share on other sites More sharing options...
jmsisco Posted June 16, 2021 Share Posted June 16, 2021 You could also make a full backup copy of your plan and keep it as an x10 plan and upgrade the other to which ever version x12 or x13 you are trying out. 1 Link to comment Share on other sites More sharing options...
lbuttery Posted June 16, 2021 Share Posted June 16, 2021 Note: plans are NOT backward compatible once upgraded to a newer version that plan can't be opened in the older version Chief makes an archive version of the older plan which can be opened in the older version but its best to make your own backups too Lew 1 Link to comment Share on other sites More sharing options...
jmsisco Posted June 17, 2021 Share Posted June 17, 2021 Chief Architect plans and layouts often contain many references to other external files so it's necessary to copy all the associated files to a new location when a plan or layout is moved. A copy of your plan along with all of your textures and materials can be quickly and easily created by using the Backup Entire Plan/Project tool. @lbutteryYes Plans are not backward compatible! Very important Point ! You can use the Backup Entire Plan Tool to make a copy the plan and all of the associated files in X10. If you have a complete x10 back up saved you will have a version that you can go back and use if you have upgraded to X12 or X13 and develop or are concerned about any compatibility issues. You could reload X10 and that complete backup has you work saved for that version. 1 Link to comment Share on other sites More sharing options...
Dermot Posted June 17, 2021 Share Posted June 17, 2021 You can either continue to work on your X10 plans in X10 or migrate them into X12 (or X13) if you want to take advantage of the new features. If you are migrating plans, using the Backup Entire Plan tool (as suggested by others) is a good way to create a backup of your old plan and make sure you don't lose any referenced files. You should not find any significant problems bringing your old plans forward, but the older they are the more likely it is that you might find some minor problems. Please feel free to always report any problems you might find to our tech support team. You may also want to review the "What's New" guides below: https://cloud.chiefarchitect.com/1/pdf/documentation/chief-architect-x11-migration-guide.pdf https://cloud.chiefarchitect.com/1/pdf/documentation/chief-architect-x12-migration-guide.pdf And if you are interested in X13 which is now available to beta test: https://www.chiefarchitect.com/whats-new/ 1 Link to comment Share on other sites More sharing options...
jkonecny Posted June 17, 2021 Author Share Posted June 17, 2021 Thanks to everyone for the advice. Very helpful! Link to comment Share on other sites More sharing options...
MoeGia Posted June 18, 2021 Share Posted June 18, 2021 I bring lots of old plans forward. Chief makes it very easy. I wouldn't hesitate to migrate plans to a new version. 1 Link to comment Share on other sites More sharing options...
KBCASC Posted June 20, 2021 Share Posted June 20, 2021 On 6/17/2021 at 10:02 AM, jkonecny said: Thanks to everyone for the advice. Very helpful! If you are going to do it?, do it now, before X13 releases, or you will pay for a 3 version upgrade , not 2, X13 will come free as you'll have SSA with the X12 Upgrade. KB 1 Link to comment Share on other sites More sharing options...
lbuttery Posted June 21, 2021 Share Posted June 21, 2021 and IF X14 is released 30 days + prior to your SSA expiration it also will be "free" the releases are usually done Q1 - X13 is running late due to Covid Lew 1 Link to comment Share on other sites More sharing options...
