Chopsaw Posted April 16, 2021 Share Posted April 16, 2021 Can anyone tell me what I am doing wrong using the Cad Detail Management feature to copy my cad details to a new cad detail and all the dimensions detach ? Link to comment Share on other sites More sharing options...
Rpadge Posted April 16, 2021 Share Posted April 16, 2021 are you using paste in place? not sure if it makes a differenc, but it might Link to comment Share on other sites More sharing options...
Chopsaw Posted April 16, 2021 Author Share Posted April 16, 2021 On 4/16/2021 at 3:55 AM, Rpadge said: are you using paste in place? not sure if it makes a difference, but it might Expand I can't get past or paste in place to work and to be honest I think it might be the first time I have use the new copy function so I wanted to be sure I was doing it correctly since the help manual is a little light on details. " • To create an exact copy of an existing CAD Detail, select it and click the Copy button. " But that make it seem pretty straight forward. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 16, 2021 Share Posted April 16, 2021 I don't seem to have that problem. Can you post an example? Link to comment Share on other sites More sharing options...
Chopsaw Posted April 16, 2021 Author Share Posted April 16, 2021 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 16, 2021 Share Posted April 16, 2021 I see now. Yes. I can definitely reproduce that. Looks like the dimensions stay associated with the original objects. You should report it. 1 Link to comment Share on other sites More sharing options...
Chopsaw Posted April 16, 2021 Author Share Posted April 16, 2021 On 4/16/2021 at 4:31 AM, Alaskan_Son said: I see now. Yes. I can definitely reproduce that. Looks like the dimensions stay associated with the original objects. You should report it. Expand I did, but wanted to be sure that I had not gone mad. Thank you for verifying that for me. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 16, 2021 Share Posted April 16, 2021 On 4/16/2021 at 4:33 AM, Chopsaw said: wanted to be sure that I had not gone mad. Expand Oh I didn't say that. Just said I could reproduce Kinda fun actually adjusting an object in one view and watching the dimensions adjust in another. Not very helpful in this case though. You can do this with roof planes too by the way. Attach a text arrow to one and then Display on Floor Above/Below. If you adjust roof plane on the new floor it affects the original arrow on the original floor. We can also get a similar behavior when dimensioning to wall framing. Oh, and also for room macros in CAD Details. Open a CAD Detail in a plan with defined rooms and you'll see that %room% macros reflect information from the actual plan view based on current room information located in that same X/Y area. The latter has some obvious benefits. The others less so. The one you've shown though seems to have no benefits at all. Link to comment Share on other sites More sharing options...
Chopsaw Posted April 16, 2021 Author Share Posted April 16, 2021 On 4/16/2021 at 4:50 AM, Alaskan_Son said: Kinda fun actually adjusting an object in one view and watching the dimensions adjust in another. Not very helpful in this case though. Expand That seems to pretty well defeat the purpose of a cad detail at least when you use the copy feature. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 16, 2021 Share Posted April 16, 2021 On 4/16/2021 at 5:02 AM, Chopsaw said: That seems to pretty well defeat the purpose of a cad detail at least when you use the copy feature. Expand I wouldn't say it defeats the purpose. Dimension and connected arrows certainly aren't doing what they should though. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 16, 2021 Share Posted April 16, 2021 Until this gets fixed, try this before copying the detail: Select All Make CAD Block Then you can Copy the CAD Detail and explode the block. If you do that, I believe the dimensions and arrows will reference only the new CAD Detail. 1 Link to comment Share on other sites More sharing options...
Chopsaw Posted April 16, 2021 Author Share Posted April 16, 2021 Thanks. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted April 16, 2021 Share Posted April 16, 2021 or place the cad detail in your lib. and get it anytime you want to. Link to comment Share on other sites More sharing options...
robdyck Posted April 16, 2021 Share Posted April 16, 2021 On 4/16/2021 at 3:54 PM, DRAWZILLA said: or place the cad detail in your lib. and get it anytime you want to. Expand And wouldn't it be nice if when you place a cad detail from the library that an option to keep the original default and layer settings would be available? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 16, 2021 Share Posted April 16, 2021 On 4/16/2021 at 3:54 PM, DRAWZILLA said: or place the cad detail in your lib. and get it anytime you want to. Expand On 4/16/2021 at 4:23 PM, robdyck said: And wouldn't it be nice if when you place a cad detail from the library that an option to keep the original default and layer settings would be available? Expand Just to be clear here, this conversation was mostly about CAD Details and not CAD Blocks. CAD Details are stored in the Project Browser and can alternatively be managed via CAD Detail Management. CAD Details cannot be stored in the library. CAD Blocks on the other hand can be stored in the library and are managed via CAD Block Management. They are 2 entirely different things with different purposes. The issue Chopsaw pointed out is an issue with copied CAD Details. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted April 16, 2021 Share Posted April 16, 2021 On 4/16/2021 at 6:27 PM, Alaskan_Son said: Just to be clear here, this conversation was mostly about CAD Details and not CAD Blocks. CAD Details are stored in the Project Browser and can alternatively be managed via CAD Detail Management. CAD Details cannot be stored in the library. CAD Blocks on the other hand can be stored in the library and are managed via CAD Block Management. They are 2 entirely different things with different purposes. The issue Chopsaw pointed out is an issue with copied CAD Details. Expand already knew all that ,all I'm trying to say is an easy way to copy a cad detail for future use, just forgot to say block it first. I have thousands of details in my lib. Never a problem Link to comment Share on other sites More sharing options...
CAmichael240114 Posted April 16, 2021 Share Posted April 16, 2021 On 4/16/2021 at 6:39 PM, DRAWZILLA said: all I'm trying to say is an easy way to copy a cad detail for future use, just forgot to say block it first. I have thousands of details in my lib. Never a problem Expand I agree absolutely, in my work flow any CAD detail that can be re-used in another plan is blocked, labeled and stored in the library Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 16, 2021 Share Posted April 16, 2021 On 4/16/2021 at 9:59 PM, CAmichael240114 said: I agree absolutely, in my work flow any CAD detail that can be re-used in another plan is blocked, labeled and stored in the library Expand I feel like you guys are missing the point, changing the subject, and confusing matters. We all know that we can store CAD Blocks in the library and that those CAD Blocks can sometimes be referred to as CAD details. What we're talking about though is very specifically the CAD Detail TOOL and what happens when you try to copy one of those CAD Details. Has nothing to do with storing anything in the library or the efficiency of doing so. Link to comment Share on other sites More sharing options...
