DougDM Posted April 3, 2021 Share Posted April 3, 2021 Good Morning and Happy Easter. I typically create my own Story Pole dims by just pulling lines off my model at points I choose. I stopped using the Auto SPD's (Story Pole Dimensions) cause I think when trying to choose different objects in more than one elevation, it would change them all. Has that changed. I. E. If I have two elevations, one is an Exterior Front Elev. and I set the story pole dims to accommodate the object of that elevation, Then when I want to change the defaults to pick other objects on for instance a rear elevation... will it screw up the first SPD's layed down for the front Elev..? Thanks for any insight. Stay Safe, Doug Link to comment Share on other sites More sharing options...
DougDM Posted April 3, 2021 Author Share Posted April 3, 2021 Tough while driving, thanks for your help. Have a Happy Easter. Link to comment Share on other sites More sharing options...
MPDesign Posted April 4, 2021 Share Posted April 4, 2021 Why on earth are you driving and posting to chief talk? If you are driving a Tesla then I can see how it would be possible with autopilot. Are you in a self-driving vehicle? Have a safe and happy Easter! Link to comment Share on other sites More sharing options...
DougDM Posted April 4, 2021 Author Share Posted April 4, 2021 I'm a passenger, My point was I 'm not in front of my computer to try, otherwise I would. Link to comment Share on other sites More sharing options...
drzahas Posted June 30, 2021 Share Posted June 30, 2021 Can anyone tell me why my "highest ridge" is so much higher the the actual highest ridge. and I can't seem to move it to the right position. I have looked for invisible walls that are tall or any feature that would be taller that I can't see and I can't seem to see anything and I cant move along in this project until I fix this. Link to comment Share on other sites More sharing options...
Kbird1 Posted June 30, 2021 Share Posted June 30, 2021 1 hour ago, drzahas said: Can anyone tell me why my "highest ridge" is so much higher the the actual highest ridge. and I can't seem to move it to the right position. I have looked for invisible walls that are tall or any feature that would be taller that I can't see and I can't seem to see anything and I cant move along in this project until I fix this. No taller building in the drawing? Scroll out and click one of the two dimension lines and look for the diamond on the end of the extension line.....grab it and pull it back to the ridge seen in the pic...use CTRL key as you pull it back / down if needed. There will be one diamond for each dimension line..... Link to comment Share on other sites More sharing options...
DougDM Posted June 30, 2021 Author Share Posted June 30, 2021 It’s reaching for something… do an all in selection window and see if anything is floating around up there. It’s happened to me, Not with story pole but just with dimensioning. You might use all on layer set to see if anything is hidden. It’s not supposed to reach for anything on an off layer, but it has happened. You may have created a solid on a wrong floor without realizing it. Just throwing out some thoughts. Also change to right side and see if it’s still up in space. Let us know. Link to comment Share on other sites More sharing options...
robdyck Posted June 30, 2021 Share Posted June 30, 2021 4 hours ago, drzahas said: Can anyone tell me why my "highest ridge" is so much higher the the actual highest ridge. Post the plan...don't make people guess. Link to comment Share on other sites More sharing options...
Kiwideziner Posted June 30, 2021 Share Posted June 30, 2021 You must have another roof plane somewhere?? Link to comment Share on other sites More sharing options...
drzahas Posted June 30, 2021 Share Posted June 30, 2021 okay sorry. new here. here is the plan. I cant seem to move the line. but Ill keep stabbing until i figure it out. karen ct.dwg Link to comment Share on other sites More sharing options...
drzahas Posted July 1, 2021 Share Posted July 1, 2021 also I am having trouble getting the roof to be a trussed roof other than a rafter roof. I currently have half raftered and the otherside shows no framing now that i have switched it ro trusses Link to comment Share on other sites More sharing options...
drzahas Posted July 1, 2021 Share Posted July 1, 2021 reposted as a new topic. with an updated .dwg Link to comment Share on other sites More sharing options...
Kbird1 Posted July 1, 2021 Share Posted July 1, 2021 1 hour ago, drzahas said: reposted as a new topic. with an updated .dwg You need to post the CA .plan file not export a dwg and post it Link to comment Share on other sites More sharing options...
