KReads Posted January 10, 2021 Share Posted January 10, 2021 Hi all. I have a fixture object that won't accept selection; can't click on it.. Surrounding it doesn't work. Turned layers off and on, double clicked the plan view in Project Browser to reset it, and restarted CA. Rebooted the computer. I only have one plan view open. I see from other posts that this has been an issue before but double clicking on the plan view to reset it worked. That hasn't worked in this case. Anyone else seen this? Link to comment Share on other sites More sharing options...
Chrisb222 Posted January 10, 2021 Share Posted January 10, 2021 Looks like a sink. Did you drag a sink out of a cabinet? If so you can't select the sink directly, have to select the cabinet first. Wherever it is... 1 Link to comment Share on other sites More sharing options...
Kiwideziner Posted January 10, 2021 Share Posted January 10, 2021 Either chris's idea or possibly a locked layer? Link to comment Share on other sites More sharing options...
KReads Posted January 10, 2021 Author Share Posted January 10, 2021 Right-o Chris. It is a sink that was in a base cabinet. Don't know how I deleted the cabinet without the sink. Checked, and it's not a locked layer. I attached the plan file. Driftwood Plan 3.02.11.zip Link to comment Share on other sites More sharing options...
rgardner Posted January 10, 2021 Share Posted January 10, 2021 14 minutes ago, KReads said: Right-o Chris. It is a sink that was in a base cabinet. Don't know how I deleted the cabinet without the sink. Checked, and it's not a locked layer. I attached the plan file. Driftwood Plan 3.02.11.zip Delete this cabinet as it is tied to that one. FYI you can use a fixture schedule to find the errant cabinet. Link to comment Share on other sites More sharing options...
MarkMc Posted January 10, 2021 Share Posted January 10, 2021 You can also just select that cabinet, hit tab, then delete. Link to comment Share on other sites More sharing options...
KReads Posted January 11, 2021 Author Share Posted January 11, 2021 rgardner: Good grief! So simple. Thanks for helping this novice. F1 key...thanks Mark.. Link to comment Share on other sites More sharing options...
rgardner Posted January 11, 2021 Share Posted January 11, 2021 2 hours ago, MarkMc said: You can also just select that cabinet, hit tab, then delete. In this case he thought he had deleted the cabinet so couldn’t find it. But yea this is true once you know the cabinet selecting it and hitting tab will allow you to select just the sink to delete. Link to comment Share on other sites More sharing options...
