Weird lines by dormer
Jambruins
  • 2 weeks later...
I am not quite sure what is causing it but they are artifacts of the side walls of the auto dormers.  You will likely need to explode the dormers and work with the walls manually to eliminate that problem.  When I opened the file the vertical artifacts were present but not the two angled pieces that appear to be joining them.
Also two ceiling surface artifacts behind the main ridge that will clear up when you combine the two main roof planes on the rear and then join them to the upper edge of the dormer roof plane.
Edited by Chopsaw
See Below for better answers.
Doug I think Steve found the key issue.  The manual ceiling planes were causing all of the noted artifacts above the roof line.
Try selecting both of the roof planes in plan view and hit the "Polyline Union" tool to combine them. :o
Ok I will have a look at that as well. Thanks Michael.
