RTX 3080 driver issues
dskogg
5 hours ago, dskogg said:
i installed a number of versions... so if i roll back it will just go back to one that didnt work either...
With Nvidia Drivers , you normally just run the Installer for the Version you want to use and use the Custom Install option and check the box for a Clean install but things can get messed up in which case I'd suggest using DDU Uninstaller with Nvidia Option checked. While DDU suggests using it from Safe Mode it will work in my experience just fine without  that. Once run I would re-install whatever driver Dell sent with the system initially and see what happens.
https://www.wagnardsoft.com/forums/viewtopic.php?f=5&t=3403
43 minutes ago, dskogg said:
Chief said maybe a windows update triggered it, it is now disabled so that should stop the issue.
More likely an Audio Driver Update from Dell, which triggered the Windows Store to update the Sonic Studio and Sonic Radar Windows Apps.
On my laptop if I uninstall Sonic Radar ONLY Chief works fine but others with Dells have all been advised to remove both ... not sure why, and can't test as I don't have a Dell and their Command Center.
2 hours ago, Rashid_Garuba said:
I bought an MSI laptop in June and Chief ran fine until November, then the problem began.. I dearly miss Windows 7..
It's not a Windows Issue perse, it is the Nahimic Sonic Radar App that Windows Update/ Windows Store automatically updates when Windows updates the Nahimic Drivers.
You can stop Windows Update from Updating Drivers quite easily if you'd like too ? , this also stops the App updating usually as the app needs to be compatible with the Driver....
I use the .reg file from 10 Forums ( get the enable and disable files) but there are other ways to do it too....
https://www.tenforums.com/tutorials/48277-enable-disable-driver-updates-windows-update-windows-10-a.html
More on Nahimic
https://www.nahimic.com/gamers/
