divreig Posted November 19, 2020 Share Posted November 19, 2020 Has any one used home designer? When you first start a new plan it gives you default styles templets you can choose form. Wondering if Chief has something like this or a library we can download them? Screen shot attached if that's helpful. - Thanks! 1 Link to comment Share on other sites More sharing options...
Chopsaw Posted November 19, 2020 Share Posted November 19, 2020 X9 shipped with all of those styles of template plan files but they got away from that in later versions but they can still be used or custom built with an up to date template file that you customize. Link to comment Share on other sites More sharing options...
SNestor Posted November 19, 2020 Share Posted November 19, 2020 Chief X12 ships with "templates"....each template has different cabinets, doors, windows, exterior wall colors or materials. Templates that ship with Chief; - American Casual.plan - Colonial.plan - Arts and Crafts.plan - Mediterranean Influence.plan - Cottage.plan Just to name a few... Link to comment Share on other sites More sharing options...
Chopsaw Posted November 19, 2020 Share Posted November 19, 2020 10 minutes ago, SNestor said: Chief X12 ships with "templates" I might be wrong Steve but I don't think they are all being shipped any more. Could you have brought those templates forward ? Take a look here: C:\Program Files\Chief Architect\Chief Architect Premier X12 (64 bit)\Templates Link to comment Share on other sites More sharing options...
divreig Posted November 19, 2020 Author Share Posted November 19, 2020 Where ? I looked in "D:\Users\tench\Documents\Chief Architect Premier X12 Data\Templates" no luck. There should be a library that would be nice. Link to comment Share on other sites More sharing options...
Chopsaw Posted November 19, 2020 Share Posted November 19, 2020 Eric, Are you suggesting that a HD template would work fine in Premier ? Link to comment Share on other sites More sharing options...
Kbird1 Posted November 19, 2020 Share Posted November 19, 2020 1 hour ago, Chopsaw said: I might be wrong Steve but I don't think they are all being shipped any more. Could you have brought those templates forward ? Take a look here: C:\Program Files\Chief Architect\Chief Architect Premier X12 (64 bit)\Templates They removed the Plan Templates which were basically just cabinets of each type, in X10 but in X11 I think they brought them back as "Cabinet Styles Templates" which is what Steve is referring too. Link to comment Share on other sites More sharing options...
ricatic Posted November 19, 2020 Share Posted November 19, 2020 I have been using HD2020 2021 Pro for a year,,,I have the trial version of Chief X12...you can easily open the design templates in HD Pro from X12...and then draw in X12...the files are found in the HD pro/data/templates folder...I have not tried to do this using a trial version of HD Pro...hope this helps Good luck Regards Rick Link to comment Share on other sites More sharing options...
SNestor Posted November 19, 2020 Share Posted November 19, 2020 @Kbird1 I have no idea if I've brought the templates forward...but, they all appear in my X12 template directory. I had no idea Chief had eliminated templates. I always tell new users to use the "residential" template to start out with, make a copy of it and start making it their own template. I never use any of the other templates. They are just there...like the sun in the sky. Link to comment Share on other sites More sharing options...
Kbird1 Posted November 19, 2020 Share Posted November 19, 2020 1 hour ago, SNestor said: @Kbird1 I have no idea if I've brought the templates forward...but, they all appear in my X12 template directory. I had no idea Chief had eliminated templates. I always tell new users to use the "residential" template to start out with, make a copy of it and start making it their own template. I never use any of the other templates. They are just there...like the sun in the sky. there is a thread here somewhere on the forum where I posted the old "Style" template files from x9 ...so not sure if you got those or brought them forward when Migrating to newer Versions. M. Link to comment Share on other sites More sharing options...
SNestor Posted November 19, 2020 Share Posted November 19, 2020 @Kbird1 - I don’t believe I ever got them from this forum. My belief is that I’ve always had them. Link to comment Share on other sites More sharing options...
divreig Posted November 20, 2020 Author Share Posted November 20, 2020 23 hours ago, solver said: Have you? Yes but after i posted i just copied the plan files form HD to x12 and it worked fine. Still should have some sort of library to share between users or even for pmt. I am just to lazy for these details I normally don't do the interior design work and just want my rendering to look not so blah like the default templet. Link to comment Share on other sites More sharing options...
Chopsaw Posted November 20, 2020 Share Posted November 20, 2020 10 minutes ago, divreig said: Yes but after i posted i just copied the plan files form HD to x12 and it worked fine. Still should have some sort of library to share between users or even for pmt. I am just to lazy for these details I normally don't do the interior design work and just want my rendering to look not so blah like the default templet. I think maybe it got to the point that Premier users were not inclined to make use of the stock templates because most of us have so many other default settings and content that to change styles is not significant and usually needs to be customized for each custom build any way. If that is not the case for you maybe @Kbird1 could find and provide the link to the X9 files he was referring to and you could add them to your library. Link to comment Share on other sites More sharing options...
Kbird1 Posted November 20, 2020 Share Posted November 20, 2020 7 hours ago, Chopsaw said: If that is not the case for you maybe @Kbird1 could find and provide the link to the X9 files he was referring to and you could add them to your library. CA Style Templates X10.zip...............Posted January 14, 2019 (chiefarchitect.com) Mick 1 Link to comment Share on other sites More sharing options...
rgardner Posted November 20, 2020 Share Posted November 20, 2020 With the invent of Style Palettes in X12 it kind of becomes a moot point anyways. As mentioned above a premier user usually has spent many hours fine tuning their template and wants all their settings on every job so they would be better off taking advantage of setting up style palettes to make the changes. 1 Link to comment Share on other sites More sharing options...
