GeneDavis Posted October 16, 2020 Share Posted October 16, 2020 And I have searched Chief Help, explored everything I can find in Defaults and Preferences, and done a search at Chieftalk. Link to comment Share on other sites More sharing options...
robdyck Posted October 16, 2020 Share Posted October 16, 2020 Type "mouse properties" into the windows search bar. Link to comment Share on other sites More sharing options...
GeneDavis Posted October 16, 2020 Author Share Posted October 16, 2020 I did and searched and see no way to get the circle behind. I want a circle in dayglo yellow. Link to comment Share on other sites More sharing options...
robdyck Posted October 16, 2020 Share Posted October 16, 2020 I can tell you that the circle you see in some of the videos myself and others use is inherent to the screen recording app. I use Flashback Express, and it adds that circle automatically for recordings only, it isn't a cursor setting. I'll see if I can find any thing else to help you out. Link to comment Share on other sites More sharing options...
rgardner Posted October 16, 2020 Share Posted October 16, 2020 9 minutes ago, robdyck said: Type "mouse properties" into the windows search bar. I am not a windows user but I believe the key to Rob's direction here is the "WINDOWS SEARCH BAR". 4 minutes ago, GeneDavis said: I did and searched and see no way to get the circle behind. I want a circle in dayglo yellow. I believe that is an operating system setting and not a chief specific tool. https://www.google.com/search?sxsrf=ALeKk01TSqT6oYePzLxqn1AVxmaQg5ElFw%3A1602860931854&ei=g7eJX6LmM-mG5wLC85PgBw&q=mouse+highlighter+windows&oq=mouse+highlighter+windows&gs_lcp=CgZwc3ktYWIQAzIHCAAQyQMQCjIECAAQCjoHCAAQRxCwAzoGCAAQFhAeUJESWJsYYIQZaAFwAHgAgAGPAYgBlwaSAQMwLjaYAQCgAQGqAQdnd3Mtd2l6yAEIuAECwAEB&sclient=psy-ab&ved=0ahUKEwjis96jsrnsAhVpw1kKHcL5BHwQ4dUDCA0&uact=5#kpvalbx=_h7eJX6PQOaOL5wKH6I_ACw13 Link to comment Share on other sites More sharing options...
robdyck Posted October 16, 2020 Share Posted October 16, 2020 I can't find a cursor setting that has a filled circle behind it, however if improved visibility is the goal, there are plenty of settings within the "mouse pointer" settings. You can easily increase the pointer size and color. In "additonal mouse settings" there are more options for cursor types. And there are third party apps for downloading custom cursor types, if you're not afraid of potential malware being installed! Link to comment Share on other sites More sharing options...
Kbird1 Posted October 18, 2020 Share Posted October 18, 2020 I use the Ease of Access in Settings in Windows 10 to make the Cursor Yellow , it is not used in all of Chief ie in the Drawing Window, but is used in all areas that Windows 10 controls. * as noted I believe the yellow circle is used by numerous Video recording Apps but can't be set as a "normal" cursor. Link to comment Share on other sites More sharing options...
Ridge_Runner Posted October 20, 2020 Share Posted October 20, 2020 I followed Ryan's link above and the clicked on this guy. Followed his method and mine is working fine so far. It is not difficult to change but you have to watch the video and follow the steps. [edit] I was using Mick's method above before that. Link to comment Share on other sites More sharing options...
