andr0id Posted August 19, 2020 Share Posted August 19, 2020 Hi there! Anybody have any suggestions as to how I would add fancy tails to my deck beams as shown in the photo? The deck tools seem pretty inflexible in this regard. Thank you! Link to comment Share on other sites More sharing options...
andr0id Posted August 19, 2020 Author Share Posted August 19, 2020 Is that a "Deck Beam"? How did you manage to add the tail? Link to comment Share on other sites More sharing options...
DavidJPotter Posted August 19, 2020 Share Posted August 19, 2020 He set up his rafter tail molding profile, built a rafter and then placed the custom rafter under the deck. One can also just create a custom polyline solid to emulate just the rafter tail and add that to the end of the deck framing manually. DJP Link to comment Share on other sites More sharing options...
andr0id Posted August 19, 2020 Author Share Posted August 19, 2020 2 minutes ago, DavidJPotter said: He set up his rafter tail molding profile, built a rafter and then placed the custom rafter under the deck. One can also just create a custom polyline solid to emulate just the rafter tail and add that to the end of the deck framing manually. DJP Ah, so he replaced the beam with a rafter! I still have to learn all the ways to cheat in CA to get what I want! I see that adding a poly tail though might get a more reliable materials list. Thank you! Link to comment Share on other sites More sharing options...
justmejerry Posted August 19, 2020 Share Posted August 19, 2020 You can just use a molding line and rafter tail or custom molding of your own creation to do same thing. No need to create a rafter first. Link to comment Share on other sites More sharing options...
Kbird1 Posted August 21, 2020 Share Posted August 21, 2020 On 8/19/2020 at 10:59 AM, andr0id said: Ah, so he replaced the beam with a rafter! I still have to learn all the ways to cheat in CA to get what I want! I see that adding a poly tail though might get a more reliable materials list. Thank you! I don't believe P-Solids get added to material lists or Schedules but have the advantage of being able to be added to the Library for future use , unlike Framing Members , but if the ML is important then using framing eg a Rafter is the way to go and maybe why Eric used that method. M. Link to comment Share on other sites More sharing options...
glennw Posted August 21, 2020 Share Posted August 21, 2020 34 minutes ago, Kbird1 said: I don't believe P-Solids get added to material lists Mick, I am pretty sure they get added to the ML as Exterior Trim. Link to comment Share on other sites More sharing options...
Kbird1 Posted August 21, 2020 Share Posted August 21, 2020 8 hours ago, glennw said: Mick, I am pretty sure they get added to the ML as Exterior Trim. Guess I need to do some testing then ....I've seen a number of posts in the past that said they didn't but I may have assumed not in a Schedule as to mean also not in the ML?. Considering what P-Solids get used for , having them all in with the Exterior "Trim" probably isn't a good thing either though.... M. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted August 21, 2020 Share Posted August 21, 2020 16 hours ago, glennw said: Mick, I am pretty sure they get added to the ML as Exterior Trim. That's where they get sent automatically, but you can click on the Components tab and Object Information tab and change whatever you want to get them to report to wherever you want. Here I have a beach ball set to report to the Framing category as a treated 4x12 deck beam... Link to comment Share on other sites More sharing options...
