robdyck Posted August 11, 2020 Share Posted August 11, 2020 Something I've never noticed before: How do you get Chief to automatically build a proper, straight header across an arched door? This is what I currently get with auto framing: Link to comment Share on other sites More sharing options...
DzinEye Posted August 11, 2020 Share Posted August 11, 2020 That looks just swell! Never noticed either. Also that doesn't look like a 9.5" deep header per your dbx. Frame with a non-arched door then change to arch and don't rebuild framing... Grrr? Link to comment Share on other sites More sharing options...
GeneDavis Posted August 11, 2020 Share Posted August 11, 2020 Just edit the framing to what you want. Make the framers jigsaw some lumber if you want to have a laugh. It is not uncommon to see bandsawn fill members nailed into an otherwise rectilinear and properly headed opening, so as to get the required backing for finish, and nailing flange bearings. But you know that. 1 Link to comment Share on other sites More sharing options...
robdyck Posted August 11, 2020 Author Share Posted August 11, 2020 9 minutes ago, DzinEye said: That looks just swell! Never noticed either. Also that doesn't look like a 9.5" deep header per your dbx. Frame with a non-arched door then change to arch and don't rebuild framing... Grrr? I'll just edit the framing. This plan is part of my garage plans for which I develop wall framing details and materials lists...because they are so simple and there's no way Chief can screw them up!!!!! Interestingly enough, it seems you can't reshape the cut end of a header. Gotta use a general framing member for the header so that the fn tools work. Unreal. Takes longer to cut a header in Chief than it does on a jobsite! Link to comment Share on other sites More sharing options...
Ridge_Runner Posted August 11, 2020 Share Posted August 11, 2020 1 minute ago, robdyck said: because they are so simple and there's no way Chief can screw them up!!!!! Good chuckle for me this morning. Thanks. 1 Link to comment Share on other sites More sharing options...
robdyck Posted August 11, 2020 Author Share Posted August 11, 2020 3 minutes ago, Ridge_Runner said: Good chuckle for me this morning. Thanks. Yup. Hilarious. LMAO over here too. And because it's a 3.5" LVL, I'm gonna need to use my big saw to get through that piece on my monitor! I may just haul out the chainsaw for this one. Yup, the chainsaw will be the easiest way to finish the cut. The circular saw would be stopped my desk! Too awkward...and that would just tick me off. Link to comment Share on other sites More sharing options...
robdyck Posted August 11, 2020 Author Share Posted August 11, 2020 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted August 11, 2020 Share Posted August 11, 2020 19 minutes ago, robdyck said: Interestingly enough, it seems you can't reshape the cut end of a header. When you can't get the Trim/Extend tools to work, try the Join & Lap/Miter tools instead. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted August 11, 2020 Share Posted August 11, 2020 2 hours ago, robdyck said: How do you get Chief to automatically build a proper, straight header across an arched door? This only happens when the resulting available space for your header is less than the header you have specified. To get the desired header, either reduce the Header Depth, lower the top of the door, or reduce the Rough Opening Top and/or Bottom settings. 3 Link to comment Share on other sites More sharing options...
robdyck Posted August 11, 2020 Author Share Posted August 11, 2020 3 minutes ago, Alaskan_Son said: This only happens when the resulting available space for your header is less than the header you have specified. To get the desired header, either reduce the Header Depth, lower the top of the door, or reduce the Rough Opening Top and/or bottom settings. Thanks Michael! If you'd been a bit quicker, I wouldn't have this mixed gas spill on my carpet! Link to comment Share on other sites More sharing options...
steve_stuart Posted August 11, 2020 Share Posted August 11, 2020 44 minutes ago, Alaskan_Son said: try the Join & Lap/Miter tools instead. @Alaskan_Son thank you 1 Link to comment Share on other sites More sharing options...
