Fergie Posted July 30, 2020 Share Posted July 30, 2020 Hello all, I have a problem in "wall view" mode with a window not showing, while others are and a fireplace not appearing. They are turned on in display options. The do show in cross sections views. Attached are some pics. Thanks in advance. Link to comment Share on other sites More sharing options...
Kbird1 Posted July 30, 2020 Share Posted July 30, 2020 You'll need to post the plan for this one - it's always the best idea anyway.....otherwise it is just a game of 20 questions which some won't play.... M. Link to comment Share on other sites More sharing options...
Fergie Posted July 30, 2020 Author Share Posted July 30, 2020 Thank you. Link to comment Share on other sites More sharing options...
joey_martin Posted July 30, 2020 Share Posted July 30, 2020 Some of those fixtures...like the FP, wont show in the wall camera. It has something to do with it talking a shot of the wall and not what's beyond it. I just leave it and move on. Link to comment Share on other sites More sharing options...
Dermot Posted July 31, 2020 Share Posted July 31, 2020 My guess is that you created the fireplace using walls and created a new room. Wall elevations only show objects in the current room where the camera is drawn. If this is not the problem, then you should do as Mick suggested and post the plan. If all else fails, then you might want to contact tech support for more help. Link to comment Share on other sites More sharing options...
mtldesigns Posted July 31, 2020 Share Posted July 31, 2020 Its definitely because your using a room camera, another hint is that the cathedral ceiling doesn't show up either. If you want all these things on your section, then use the cross section and narrow the view with "clip to sides" in the cross section dbx. Dermot, I know we've suggested a fix to this in the past. Is this a possibility of getting corrected on future releases? A wall camera should at least show the correct ceiling, and not be based on ceiling height set in the room def dbx 1 Link to comment Share on other sites More sharing options...
Fergie Posted July 31, 2020 Author Share Posted July 31, 2020 15 hours ago, mtldesigns said: Its definitely because your using a room camera, another hint is that the cathedral ceiling doesn't show up either. If you want all these things on your section, then use the cross section and narrow the view with "clip to sides" in the cross section dbx. Dermot, I know we've suggested a fix to this in the past. Is this a possibility of getting corrected on future releases? A wall camera should at least show the correct ceiling, and not be based on ceiling height set in the room def dbx Agreed. I'll use the cross-section view for that room. Mainly wanting if for window information/detail and was surprised that the window/fireplace didn't show in the wall camera but does show up in the cross-section. It just seems odd that it doesn't work similarly in both views. Thanks everyone. Link to comment Share on other sites More sharing options...
Dermot Posted July 31, 2020 Share Posted July 31, 2020 Quote Dermot, I know we've suggested a fix to this in the past. Is this a possibility of getting corrected on future releases? A wall camera should at least show the correct ceiling, and not be based on ceiling height set in the room def dbx. Of course there is a possibility. We have every intention of implementing all of the feature requests that we have received. Given that we currently have about 9,000 feature requests in our database, and we are only able to implement about 100 of them each release, I would say the possibility of any particular one getting in the next version at somewhere around 1 in 900. Those odds actually get much worse if it's a feature request that we don't know anything about since we don't look for feature requests hidden in the Q&A forum. The best way to make sure the features that you think are important are brought to our attention is to post them on the suggestions forum here: https://chieftalk.chiefarchitect.com/forum/8-suggestions/ Link to comment Share on other sites More sharing options...
Alaskan_Son Posted July 31, 2020 Share Posted July 31, 2020 38 minutes ago, Dermot said: We have every intention of implementing all of the feature requests that we have received In the overall defense of your case, I think this may be a bit of hyperbole. As you know, it's a lot more complicated than that. You obviously can't simultaneously implement conflicting requests and I would absolutely fault you for implementing requests that are obviously flawed in some way. Link to comment Share on other sites More sharing options...
