Changing how walls look in plan view
JeremyNeilKelly
In Display Options for this plan view you should make sure these layers are unchecked: Main Layer Only which will not show any fills or hatching, that command shows only the "Main Layer" for walls.
Chopsaw's suggestion is also a good one to check for.
What ever it is found to be it WILL be a setting or layer on or off that is denying you of your desired outcome.
