Doug_N Posted June 10, 2020 Share Posted June 10, 2020 I am curious about how to enforce wall alignment when CA doesn't want to cooperate. (Maybe because of my understanding of preferences or configuration). Please see the attached file for a view of the problem. Wall Alignment.zip Link to comment Share on other sites More sharing options...
robdyck Posted June 10, 2020 Share Posted June 10, 2020 Wall Definition: "Foundation to Exterior of"..your most exterior layer. Link to comment Share on other sites More sharing options...
Doug_N Posted June 10, 2020 Author Share Posted June 10, 2020 That doesn't seem to work for a second floor Link to comment Share on other sites More sharing options...
DzinEye Posted June 10, 2020 Share Posted June 10, 2020 Looks to me like the OOB main layers (studs) are lining up, so I think you'll need to change the location of the main layer in your upper wall definition to whatever other material in the upper wall should line up with the main layer on your lower wall. Link to comment Share on other sites More sharing options...
LevisL Posted June 10, 2020 Share Posted June 10, 2020 If you change your general wall defaults, you can manually move the walls into place and have them snap to the reference walls below. The 'Align with wall below' tool still won't work like you want though. Not quite automatic like you requested, but it'll be accurate. Link to comment Share on other sites More sharing options...
DzinEye Posted June 10, 2020 Share Posted June 10, 2020 Link to comment Share on other sites More sharing options...
Doug_N Posted June 11, 2020 Author Share Posted June 11, 2020 You're right, it is better but still not aligned. The wall still requires manual adjustment to get the outer wall surface to match. Link to comment Share on other sites More sharing options...
rgardner Posted June 11, 2020 Share Posted June 11, 2020 5 minutes ago, Doug_N said: You're right, it is better but still not aligned. The wall still requires manual adjustment to get the outer wall surface to match. Try posting a pic of the wall definitions for each wall. Link to comment Share on other sites More sharing options...
DzinEye Posted June 11, 2020 Share Posted June 11, 2020 19 minutes ago, Doug_N said: You're right, it is better but still not aligned. The wall still requires manual adjustment to get the outer wall surface to match. Doug, didn't realize you included your plan file until just now. Anyway, I should've realized this before but you'll also need to move the OSB into the Main Layer on your lower wall... then they'll line up on the outside 1 Link to comment Share on other sites More sharing options...
DzinEye Posted June 11, 2020 Share Posted June 11, 2020 I was just looking at the walls lined up per the pic above. Now looking in 3D I see you'll also need to define that the upper walls "Build Platform to" setting goes to the insulation layer so your wall closes up between floors Link to comment Share on other sites More sharing options...
Doug_N Posted June 11, 2020 Author Share Posted June 11, 2020 8 minutes ago, DzinEye said: Doug, didn't realize you included your plan file until just now. Anyway, I should've realized this before but you'll also need to move the OSB into the Main Layer on your lower wall... then they'll line up on the outside You nailed it Mark. Well done, and thanks! Link to comment Share on other sites More sharing options...
