Christina_Girerd Posted May 31, 2020 Share Posted May 31, 2020 Trying another feature I don't normally use, the lintel extension for a door. I thought I could quickly use the door lintel extension to have a unified lintel across the door and two side window. It showed fine in the preview window, but upon closing the dbx, it only shows the lintel exactly over the door, as is shown in the image. I lowered the windows down farther than I really want, just to see if they were causing a conflict, and they are now definitely lower than the lintel, so it doesn't seem they are the problem. I know I can just draw a lintel manually, but now I'm curious why this isn't working as I expected. Link to comment Share on other sites More sharing options...
Ridge_Runner Posted May 31, 2020 Share Posted May 31, 2020 My guess, and it's just a guess, is that it confuses CA. The program knows windows can have their own lintels so it just doesn't know what to do with that wider door lintel. Link to comment Share on other sites More sharing options...
Christina_Girerd Posted May 31, 2020 Author Share Posted May 31, 2020 I deleted the windows, and it still won't extend. Not worth messing with more at this point, I'll just put on a manual one. Thanks for the suggestions. Link to comment Share on other sites More sharing options...
Chopsaw Posted May 31, 2020 Share Posted May 31, 2020 Try the delete surfaces tool. For some reason if the door is recessed the lintel gets buried into the wall. Why ? That would be for Chief to answer. I guess we need a Thickness setting or Display on Surface option. Link to comment Share on other sites More sharing options...
Chopsaw Posted May 31, 2020 Share Posted May 31, 2020 2 minutes ago, solver said: Doesn't seem to be a problem here. Door recessed to main layer, windows to sheathing. Humm.... Try a Stucco-6. Not sure what is up with that ? Link to comment Share on other sites More sharing options...
Chopsaw Posted May 31, 2020 Share Posted May 31, 2020 4 minutes ago, solver said: Looks like you need a thicker lintel via a molding profile I know it is getting late but if I choose a CA-001 then where do I set the thickness ? I think Christina found a Bug. Link to comment Share on other sites More sharing options...
Chopsaw Posted May 31, 2020 Share Posted May 31, 2020 15 minutes ago, solver said: You can't. The thickness is set in the molding profile. You can only change the height via the DBX. Ok maybe not a Bug. Just another confusing inconsistency in that you can control the "Depth" of the Casing in the DBX but if you want to change the depth of the Lintel using the same molding profile you need to draw your own custom profile. Not like they ran out of room in the Lintel DBX !!! 5 minutes ago, solver said: Maybe this should be how it works? That looks good. Not really practical for waterproofing though. But ok if used over windows. WMR ?? Link to comment Share on other sites More sharing options...
DzinEye Posted May 31, 2020 Share Posted May 31, 2020 25 minutes ago, Chopsaw said: Ok maybe not a Bug. Just another confusing inconsistency in that you can control the "Depth" of the Casing in the DBX but if you want to change the depth of the Lintel using the same molding profile you need to draw your own custom profile. Not like they ran out of room in the Lintel DBX !!! Not a bug, but it sure bugs me. There are some other similar inconsistencies like that too, which I can't recall at the moment.. same thing where we can't control all dimensions of something which we can in a different dbx. Link to comment Share on other sites More sharing options...
Kbird1 Posted May 31, 2020 Share Posted May 31, 2020 5 hours ago, Christina_Girerd said: I deleted the windows, and it still won't extend. Not worth messing with more at this point, I'll just put on a manual one. Thanks for the suggestions. If you mull the 3 units together can you then add the Lintel Christina? pretty sure I have done it that way before.... M. Link to comment Share on other sites More sharing options...
Christina_Girerd Posted May 31, 2020 Author Share Posted May 31, 2020 When I mulled the the door and windows, then the lintel worked as expected. Unfortunately, after that, I realized that the frame and lintel are a single material, so I can't give the lintel it's own material and the client wants a stone lintel, so I'm back to the manual lintel anyway. Oh well! Link to comment Share on other sites More sharing options...
robdyck Posted June 1, 2020 Share Posted June 1, 2020 19 hours ago, Christina_Girerd said: When I mulled the the door and windows, then the lintel worked as expected. Unfortunately, after that, I realized that the frame and lintel are a single material, so I can't give the lintel it's own material and the client wants a stone lintel, so I'm back to the manual lintel anyway. Oh well! The lintel will have its own material as long as there is an actual molding profile specified. When no molding profile is chosen it uses the exterior trim material. Link to comment Share on other sites More sharing options...
Christina_Girerd Posted June 1, 2020 Author Share Posted June 1, 2020 I just tried it again, and yes, I could give the lintel a separate material. I did have a molding profile for the lintel, but I was looking at it in a 3D view, and I'm guessing I accidentally spray painted the material in object mode instead of component and thus thought I couldn't change it individually. I thought I had also looked to see if it listed a material separately for the lintel, but maybe not. Anyway, good to know you can use a separate material for the lintel and I just missed it somehow. Thanks. Link to comment Share on other sites More sharing options...
