Doug_N Posted March 31, 2020 Share Posted March 31, 2020 Is there a way to add comments to a room schedule. I would like to include "existing" or "proposed" to any given room. Link to comment Share on other sites More sharing options...
robdyck Posted March 31, 2020 Share Posted March 31, 2020 A note works best. Just make a new note type and use it for your room schedule. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted March 31, 2020 Share Posted March 31, 2020 Or just add existing or new to the room name (E), (N). It will show in the room finish schedule. Link to comment Share on other sites More sharing options...
Doug_N Posted April 1, 2020 Author Share Posted April 1, 2020 What I am hoping to do is what is done for windows, doors and for that matter walls. Here is an example for windows. But for rooms, no such joy. Adding existing or proposed to the name of the room creates clutter in the drawing, and is not ideal. Adding text to each line in the schedule is cumbersome at best and if done with notes requires the addition of a note in each room. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted April 1, 2020 Share Posted April 1, 2020 how about adding (N), (E) to the room name, I;'ve been doing it that way for many years. add an explanation to the heading Link to comment Share on other sites More sharing options...
Doug_N Posted April 1, 2020 Author Share Posted April 1, 2020 2 minutes ago, DRAWZILLA said: how about adding (N), (E) to the room name, I;'ve been doing it that way for many years. I see this as a workaround and not as a solution. It kind of works if you only have new and existing, but doesn't allow for extended comments. Client Option, Client to Specify, Renovated west wall only etc. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 1, 2020 Share Posted April 1, 2020 The Note method is really all we have right now and its really not a bad solution. It can all pretty easily be set up with custom macros to be fully automated so all you have to do is copy and paste the note from room to room as you go. Link to comment Share on other sites More sharing options...
Doug_N Posted April 1, 2020 Author Share Posted April 1, 2020 Thanks for the suggestion Michael and Robert. For now, I guess that is what I will use. And to you Perry (Drawzilla), I am sorry if I came across as being curt. Just going through a really grumpy phase right now. 1 Link to comment Share on other sites More sharing options...
robdyck Posted April 1, 2020 Share Posted April 1, 2020 Don't forget Doug, that you can add all sorts of additional information to a 'template' note type and then, as Michael said, just copy, use sticky mode and drop a note into every room. You are correct, that the OIP should be available for rooms and it has been requested for a long time...but we gotta work with what we've got! Link to comment Share on other sites More sharing options...
Doug_N Posted April 1, 2020 Author Share Posted April 1, 2020 52 minutes ago, robdyck said: Don't forget Doug, that you can add all sorts of additional information to a 'template' note type and then, as Michael said, just copy, use sticky mode and drop a note into every room. You are correct, that the OIP should be available for rooms and it has been requested for a long time...but we gotta work with what we've got! And bug the developers to include it in the "Suggestions" part of the forum too. At least in my, sometimes not so humble, opinion Link to comment Share on other sites More sharing options...
Joe_Carrick Posted April 2, 2020 Share Posted April 2, 2020 I've been using a Note as the Room Number and Room Name. Then my Note Schedule is the Room Schedule. It allows Custom Fields to be use so you can add a lot of additional information. Of course most of it has to be done with custom macros in those fields. 1 Link to comment Share on other sites More sharing options...
