Dave13 Posted October 19, 2014 Share Posted October 19, 2014 I know the answer to this question but damm if I can remember how to get a glass shower wall to be clear and not the wall color. Yes I used the railing tool and change the wall type to glass but it still comes out with the wall color instead of tempered glass. The old memory is just not working that well anymore. Thanks for the help Link to comment Share on other sites More sharing options...
Dave13 Posted October 19, 2014 Author Share Posted October 19, 2014 Here's the picture, maybe it will post this time Link to comment Share on other sites More sharing options...
Dave13 Posted October 19, 2014 Author Share Posted October 19, 2014 Guess not Link to comment Share on other sites More sharing options...
Kbird1 Posted October 19, 2014 Share Posted October 19, 2014 see this for pic posting https://chieftalk.chiefarchitect.com/index.php?/topic/2370-screen-shots-in-forum-post/#entry18603 Link to comment Share on other sites More sharing options...
Dave13 Posted October 20, 2014 Author Share Posted October 20, 2014 Thanks for the attach pic help, forgot to hit attach file before I posted it. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted October 20, 2014 Share Posted October 20, 2014 Dave, Did you "Paint" the Room(s)? That would cause the glass walls to be painted also. You would need to reset the room finish to default and then just paint the walls rather than the room(s). Check the "Paint Mode" icons on the Edit Toolbar. Link to comment Share on other sites More sharing options...
jcaffee Posted October 20, 2014 Share Posted October 20, 2014 Make the glass wall "No room def", that way painting the "room" won't attach to the glass. Otherwise, you need to apply the finish the each wall surface individually via the wall dbx. jon Link to comment Share on other sites More sharing options...
dshall Posted October 20, 2014 Share Posted October 20, 2014 I disagree with the previous answers, the easiest way is to select the wall, open dvx, MATERIALS<INTERIOR WALLS SURFACE, and change the INTERIOR WALL SURFACE to your glass material. Also change the EXTERIOR WALL SURFACE to glass.... all will be well. This technique will override whatever color you have painted the room. The other methods will work, but this is the best and easiest solution. Link to comment Share on other sites More sharing options...
KirkClemons Posted October 20, 2014 Share Posted October 20, 2014 You need to restore the default material for the room: http://www.chiefarchitect.com/support/article/KB-00586/ At some point you used the material painter on the room and that overrides everything. Reset it to the defaults and the shower walls should look normal again. Link to comment Share on other sites More sharing options...
Dave13 Posted October 20, 2014 Author Share Posted October 20, 2014 I try to avoid the material painter but after changing wall colors a few times I get lazy and just use the painter, I used the wall specification dialog box and individually changed each wall color and I got my glass back. Now the question is how to tell whether to use the interior or exterior wall if your in a room with no exterior walls. Thanks for the help! Link to comment Share on other sites More sharing options...
KirkClemons Posted October 20, 2014 Share Posted October 20, 2014 The wall specification dialog has a preview of the wall to the right and you can rotate that around to see the interior or exterior side. Link to comment Share on other sites More sharing options...
dshall Posted October 20, 2014 Share Posted October 20, 2014 On 10/20/2014 at 2:57 PM, KirkClemons said: You need to restore the default material for the room: http://www.chiefarchitect.com/support/article/KB-00586/ At some point you used the material painter on the room and that overrides everything. Reset it to the defaults and the shower walls should look normal again. I disagree and this post is confusing Link to comment Share on other sites More sharing options...
DRAWZILLA Posted October 20, 2014 Share Posted October 20, 2014 I like to use the new wall material region tool for the walls in a shower or tub, then the glass wall stays as is. You can customize the tile any way you want. Link to comment Share on other sites More sharing options...
Kbird1 Posted October 21, 2014 Share Posted October 21, 2014 On 10/20/2014 at 3:20 PM, Dave13 said: I try to avoid the material painter but after changing wall colors a few times I get lazy and just use the painter, I used the wall specification dialog box and individually changed each wall color and I got my glass back. Now the question is how to tell whether to use the interior or exterior wall if your in a room with no exterior walls. Thanks for the help! The exterior side ( as Chief sees it) will have the edit handle on it at the center of the wall when you select it , either interior or exterior walls. M Link to comment Share on other sites More sharing options...
