DH7777 Posted January 21, 2020 Share Posted January 21, 2020 Hello, I consistently run into this issue. Notice my second floor is open to the stairwell. I used the open floor platform From second-floor working plan view....I also put an invisible wall at top of steps first so I can delete base molding before opening the floor or installing stairs. This always happens to me. Went back and repeated this process from first floor by using open ceiling platform... The same thing happens. Then I went and check to make sure all floor framing is on. It still shows zero framing! As a matter of fact, I turned all framing on and I have no framing showing up from ground-up which is weird. I have no idea what I'm doing wrong. I can delete the steps and it has no effect on this so I know the steps are irrelevant. Help please Link to comment Share on other sites More sharing options...
DH7777 Posted January 21, 2020 Author Share Posted January 21, 2020 Ok I fixed it but just dragging the drywall up or down to close in the sides which worked.(still don't know where my framing is) but in this next pic it shows the white ceiling wrapping up the floor. This I can't get rid of. Totally confused as to why this happens to me. Link to comment Share on other sites More sharing options...
Ridge_Runner Posted January 21, 2020 Share Posted January 21, 2020 May be a foolish point, but did you build framing for the floor? Link to comment Share on other sites More sharing options...
javatom Posted January 21, 2020 Share Posted January 21, 2020 Make sure the floor framing layer is turned on. Link to comment Share on other sites More sharing options...
rgardner Posted January 21, 2020 Share Posted January 21, 2020 The program doesn’t add framing till you tell it to do so. You can auto frame everything or do so wall by wall or roof panel by roof panel. In x12 you can now do it by room. Link to comment Share on other sites More sharing options...
DH7777 Posted January 21, 2020 Author Share Posted January 21, 2020 2 hours ago, Ridge_Runner said: May be a foolish point, but did you build framing for the floor? yes I did Link to comment Share on other sites More sharing options...
DH7777 Posted January 21, 2020 Author Share Posted January 21, 2020 2 hours ago, rgardner said: The program doesn’t add framing till you tell it to do so. You can auto frame everything or do so wall by wall or roof panel by roof panel. In x12 you can now do it by room. Roger that Link to comment Share on other sites More sharing options...
DH7777 Posted January 21, 2020 Author Share Posted January 21, 2020 2 hours ago, rgardner said: The program doesn’t add framing till you tell it to do so. You can auto frame everything or do so wall by wall or roof panel by roof panel. In x12 you can now do it by room. ok Link to comment Share on other sites More sharing options...
rgardner Posted January 21, 2020 Share Posted January 21, 2020 30 minutes ago, DH7777 said: yes I did If you did build it then it is probably a layer that is not on. Try turning on all layers. Link to comment Share on other sites More sharing options...
DH7777 Posted January 21, 2020 Author Share Posted January 21, 2020 2 minutes ago, rgardner said: If you did build it then it is probably a layer that is not on. Try turning on all layers. ok thanks Link to comment Share on other sites More sharing options...
Chrisb222 Posted January 22, 2020 Share Posted January 22, 2020 Did you fix this? I've had that happen in the past when I had my wall definition screwed up. Since you "run into it consistently" I'll guess your template plan has a goofy wall definition. I'm sure if you post the plan you'll get a quick solution. Link to comment Share on other sites More sharing options...
tommy1 Posted January 23, 2020 Share Posted January 23, 2020 On 1/21/2020 at 8:12 AM, DH7777 said: I used the open floor platform As mentioned, don't use that tool. Use an open below room or auto stairwell. Link to comment Share on other sites More sharing options...
