dskogg Posted January 12, 2020 Share Posted January 12, 2020 Is there a way to import room names into a plan? Link to comment Share on other sites More sharing options...
Kbird1 Posted January 12, 2020 Share Posted January 12, 2020 Yes ( maybe?? you're going to need to explain a bit more.... at least I have no clue what you are trying to do.... ) M. Link to comment Share on other sites More sharing options...
dskogg Posted January 12, 2020 Author Share Posted January 12, 2020 I have a plan that I am working on and i have somehow erased the added room types before i started plan...so now i dont have my standard room names. Link to comment Share on other sites More sharing options...
dskogg Posted January 12, 2020 Author Share Posted January 12, 2020 HI Eric, not quite sure i follow? Link to comment Share on other sites More sharing options...
Kbird1 Posted January 12, 2020 Share Posted January 12, 2020 On 1/12/2020 at 9:26 PM, dskogg said: I have a plan that I am working on and i have somehow erased the added room types before i started plan...so now i dont have my standard room names. Expand Does an archive copy still have them ? I am still not clear on how you erased Room Names? are you talking about just the room label text? Room Types or ? Link to comment Share on other sites More sharing options...
dskogg Posted January 12, 2020 Author Share Posted January 12, 2020 Eric i opened a new plan with the room names active, copied the plan and pasted it into the plan i am working on, room names did not come thru Link to comment Share on other sites More sharing options...
rgardner Posted January 12, 2020 Share Posted January 12, 2020 Is it the room label layer that is turned off then? Link to comment Share on other sites More sharing options...
Kbird1 Posted January 12, 2020 Share Posted January 12, 2020 On 1/12/2020 at 8:48 PM, Kbird1 said: at least I have no clue what you are trying to do.... Expand And apparently I am not the only one......... Link to comment Share on other sites More sharing options...
DavidJPotter Posted January 12, 2020 Share Posted January 12, 2020 https://youtu.be/ezKV4zJEbfw All about Room Names DJP Link to comment Share on other sites More sharing options...
dskogg Posted January 12, 2020 Author Share Posted January 12, 2020 On 1/12/2020 at 9:54 PM, solver said: Are you talking about Room Types? Expand Oh Yes....room types, not room names...sorry. Link to comment Share on other sites More sharing options...
dskogg Posted January 12, 2020 Author Share Posted January 12, 2020 Eric, what do you mean by copy the structure exactly...i copied the plan with the room types and pasted it into the plan and the room types did not show up in plan. Link to comment Share on other sites More sharing options...
glennw Posted January 12, 2020 Share Posted January 12, 2020 File>Import>Import Default Settings>choose a plan>Room Types 1 Link to comment Share on other sites More sharing options...
dskogg Posted January 12, 2020 Author Share Posted January 12, 2020 On 1/12/2020 at 11:54 PM, glennw said: File>Import>Import Default Settings>choose a plan>Room Types Expand Thanks Glen, that worked...it helps if i ask the right thing... How are you with all the fires? I hope you and your family are ok. Link to comment Share on other sites More sharing options...
glennw Posted January 13, 2020 Share Posted January 13, 2020 David, We are well away from the fires, but are affected by smoke and ash - visibility is very low some days. Over 1000 houses burnt and many people perished in the fires - not a good situation, but has probably got a bit better in the last few days due to cooler weather. Link to comment Share on other sites More sharing options...
DavidJPotter Posted January 13, 2020 Share Posted January 13, 2020 On 1/13/2020 at 12:03 AM, glennw said: David, We are well away from the fires, but are affected by smoke and ash - visibility is very low some days. Over 1000 houses burnt and many people perished in the fires - not a good situation, but has probably got a bit better in the last few days due to cooler weather. Expand It has been reported that the main cause of the fires was people setting them, the drought just set the stage. Can you confirm those reports, I wonder? DJP Link to comment Share on other sites More sharing options...
glennw Posted January 13, 2020 Share Posted January 13, 2020 David, I don't know if the main cause was arson, but last I heard there were 28 people arrested or charged with lighting fires. One case was a guy who started a backburn to protect his dope crop! A lot were started by lightening strikes. Certainly the drought has contributed to the ferocity of the fires. Link to comment Share on other sites More sharing options...
DavidJPotter Posted January 13, 2020 Share Posted January 13, 2020 What I have seen reported here, via Australian News sources is almost 200 persons (183 to be exact) have been arrested for arson there. I know your country is large but that is still a lot of arsonists, eh? DJP Link to comment Share on other sites More sharing options...
