Joe_Carrick Posted October 11, 2014 Share Posted October 11, 2014 It has been noted that often when copying an object in an elevation view and pasting it up or down to a different floor - it isn't copied to the floor that was intended. This is because the floor being worked on wasn't changed. If the following procedure is used the object will be pasted on the desired floor: 1. Change to the Floor that you want to Copy the Object to. ie: <1>, <2>, <3>, etc. 2. In the Elevation View, select and Copy/Paste the Object The problem would not occur if you are working in Plan View because you would automatically have changed floors before pasting but in Section or Elevation Views it's easy to forget that you need to be on the correct floor to paste the object. Note: This will not work with Transform/Replicate - it only works with the Copy/Paste Edit Tool. Link to comment Share on other sites More sharing options...
lbuttery Posted October 11, 2014 Share Posted October 11, 2014 This will not work with Transform/Replicate - it only works with the Copy/Paste Edit Tool You gotta love Chief's inconsistencies Lew 2 Link to comment Share on other sites More sharing options...
DRAWZILLA Posted October 11, 2014 Share Posted October 11, 2014 I wonder why the p-solid tool acts differently if you pick a p-solid from the toolbar, and if you pick a p-solid from the primitive solids section. From the primitive solids section it always give you the solid located at "(0)" height even if you are on the 2nd floor. From the toolbar, it puts the solid at a 2nd floor height. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted October 11, 2014 Author Share Posted October 11, 2014 Perry, P_Solids (aka Polyline Solids) and Primitive Solids are 2 different animals. You can use the boolean operations on multiple P_Solids or on multiple Primitive Solids but you can't use a boolean operation on a P_Solid and a Primitive Solid. The Primitive Solids are essentially defined/intended to be independent of any given Floor Level. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted October 11, 2014 Share Posted October 11, 2014 Then why are they both listed as p-solids from both category's EDit, ok after further review, one is listed a slab and the other a solid, but they do act differently when placed on a floor. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted October 11, 2014 Author Share Posted October 11, 2014 Perry, Perhaps I don't understand the objects you are referring to. Here are the definitions as I understand them: 1. Primitive Solids - Box, Sphere, Cylinder, Pyramid, Cone, Face 2. Special case Polyline Solid created using the Build PrimitiveTool) 3. P_Solid (Polyline Solid) - a Polyline created in either Plan or Elevation and then "Converted to a Solid" 4. Slab - Special case of a P_Solid 5. Custom Countertop- Special case of a P_Solid All items listed in #1 are distinctly different animals and can't be added to or subtracted from any of the items listed in #2, #3, #4 or #5. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted October 11, 2014 Share Posted October 11, 2014 I'm talking about the placement on floor 1 when you are on floor 2 when on floor 2 a slab will place it on floor 2 where a p-solid from the primitive tool will place it on floor 1 even when you are on floor 2. Link to comment Share on other sites More sharing options...
RL-inc Posted October 11, 2014 Share Posted October 11, 2014 I hope this isn't too off topic but since we are discussing p-line solids in elevation view I thought I would bring it up..... I use p-line solids to create belly bands and like trim in elevation. I go from wall to wall and manually create a band and then change it's layer to a new one or put it on the corner board layer then change it to the material I desire. I can transform replicate or copy if the items are in a close enough area or plane but overall it is time consuming effort.. any suggestions on a better method????? Link to comment Share on other sites More sharing options...
DRAWZILLA Posted October 11, 2014 Share Posted October 11, 2014 You can select the outside room and select room molding p-line then put it on any layer you want. where you don't want the belly band just break that line and un-check molding on this line. A lot faster method for sure. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted October 11, 2014 Author Share Posted October 11, 2014 On 10/11/2014 at 6:55 PM, RL-inc said: I hope this isn't too off topic but since we are discussing p-line solids in elevation view I thought I would bring it up..... I use p-line solids to create belly bands and like trim in elevation. I go from wall to wall and manually create a band and then change it's layer to a new one or put it on the corner board layer then change it to the material I desire. I can transform replicate or copy if the items are in a close enough area or plane but overall it is time consuming effort.. any suggestions on a better method????? Yes, Rob - that's way off topic. Just a suggestion, I think you'd get better results if you started a thread specifically asking that question. But Perry is absolutely right. Create an Exterior Room Molding Polyline. It's much faster and it can actually be copied from Floor to Floor using the technique described in my 1st post. Link to comment Share on other sites More sharing options...
Doggies1954 Posted October 11, 2014 Share Posted October 11, 2014 This will not work with Transform/Replicate - it only works with the Copy/Paste Edit Tool You gotta love Chief's inconsistencies Lew, they are two different tools. Not inconsistent at all. Both have different operations. Link to comment Share on other sites More sharing options...
lbuttery Posted October 12, 2014 Share Posted October 12, 2014 Len: seems to me that "copy" in T/R should be same as "copy/paste" the goal - clone the object and place it somewhere I have a guest in town - so no time to play and try Lew Link to comment Share on other sites More sharing options...
ebdesign Posted October 13, 2014 Share Posted October 13, 2014 Well, it does say "Copy" in the T/R dbx. "Copy" means one thing here & something else over there? Come on now, it's the same thing. If that is not the case, that's part of the problem. There ARE inconsistencies in how different things are duplicated & where they end up in plan view- depending on tool used, object type & where the task is being performed-plan or camera. One method works for some things but not others. That could be cleaned up some. IMO Link to comment Share on other sites More sharing options...
digitecht Posted November 7, 2014 Share Posted November 7, 2014 HI Im NEW Link to comment Share on other sites More sharing options...
