DH7777
Bird box frieze board
How do I get my frieze board to auto-generate all the way around the bird boxes? (connecting the eave frieze to the gable frieze). It seems to always just stop which is not how it should look. Do I need to turn something on? I have looked everywhere.
No auto for that. You'll have to do it manually. If someone else knows how...I'd love to learn that tip as well!
On 11/20/2019 at 9:29 AM, solver said:
Do you use Corner Boards?
yes, I use corner boards but they work the corners only. They don't take a 90degree turn and then turn back again to return to the gable frieze board. I was able to copy the corner board and move that one over and adjust the size by stretching it up. That worked. I just figured this would be something that would auto-generate.
It's always helpful to have images of what you want as there are so many ways of building and so many ways of doing things in Chief.
This shows 2 corner boards both auto applied. One wider shorter one for the frieze, and one as a normal corner board below.
This looks messy in anything but standard view because of the extra lines.
Fantastic tip Eric!  Amazing...
    29350
    sea_lyons
    sea_lyons
