Simple year macro
rgardner
Hi everyone, hope you are having a wonderful week so far.  I was setting up a new layout for a builder I am doing more and more work for and went to type in my ©2019 when I thought...  I wonder if there is a 4 digit year macro I can put in there so I don't have to change that every year on all my layouts???   I am new'sh to macros so still have a ton to learn.  I couldn't find it in the chief macros and I did search here on the forum but have not found it.
Anyone know what it is?  TIA for all your continued help and support.  You guys are amazing! :)
4 minutes ago, Joe_Carrick said:
Macro "year"
  • t = Time.new
  • result = t.year
returns the current year  --> 2019 as a numerical value
  • result = result.to_s
returns a character string --> "2019"
I obviously am doing something wrong because it isn´t coming out right.  What would i need to paste in there exactly to make it work. I have been trying to watch videos to figure this out but I am obviously missing a step.
My understanding is that "non-evaluated" macro can use one or many evaluated macros and any global macros ... e.g. %client.name%.
While evaluated macro in CA can never execute another macro ( at least I have never been able to figure out how module_eval, or instance_eval can execute others )
Where it could be used: let say you have
labelCeiling macro none evaluated  macro that is defined:
%showCeilingsHeight%%collectRoomInformation%
Think of it this way...
  • Evaluated = "Hey Chief, I want you to send all this text over to Ruby to execute as code".  Text macros are a pure Chief construct and have nothing to do with Ruby unless the macro is set to evaluate, and even then, it's only the code execution that involves Ruby.
  • Non-evaluated = "Hey Chief, I just want you to just use this as dumb text."
  • Anything between % signs is pure Chief and has nothing whatsoever to do with Ruby.  Ruby only sees the text value of the two % signs along with the characters between them.
  • Chief sees %macro_name% onscreen in the plan and it spits out the results of whatever that macro is whether it be evaluated or not.
Within a custom evaluated macro just include another macro you want to use in quotes.  example:
  • result = "%my_other_macro%"
Here's an example of how I use this technique to display the label differently depending on the layer_set name.
if obj.layer_set.include? "Legend"
  result = "%window_label_legend_X11%"
elsif obj.layer_set.include? "Wall Area Analysis Plan"
  result = "%wall_opening_areas%"
elsif obj.layer_set.include? "Wall Area Analysis Elevation"
elsif obj.layer_set.include? "Wall Area Analysis Plan" or obj.layer_set.include? "Wall Area Analysis Ref"
elsif obj.layer_set.include? "Framing"
  result = "%opening_header_label%"
elsif obj.layer_set.include? "Section" or obj.layer_set.include? "Elevation"
  result = obj.schedule_number + "\n" + obj.automatic_label + "\n" + obj.type_name
else
  result = obj.schedule_number + "\n" + obj.automatic_label + " " + obj.type_name
end
...and don't forget you can also use evaluated macros as methods:
macro_a = 3 ----> 3
macro_b = 7 ----> 7
macro_c = macros.macro_a + macros.macro_b ----> 10
instead of being limited to...
macro_d = "%macro_a%" + "macro_b%" ----> 37
or a non evaluated version of the same...
macro_e = %macro_a%%macro_b% ----> 37
  • 2 weeks later...
I've been wanting to automate my title block for years.  In addition to Joe's macro I added another that subtracts 1986 from the current year to give me a %years_open% value.
Thank you Joe for the answer and RGardner for asking the question!
On 11/19/2019 at 5:35 PM, Joe_Carrick said:
Macro "year"
  • t = Time.new
  • result = t.year
This is pure Ruby and doesn't require anything else from Chief.
FWIW, the extra line is actually unnecessary.
Time.new.year
or
Time.now.year
both work just fine as well.
15 minutes ago, Joe_Carrick said:
I think you meant "unnecessary".
Ya, that would make more sense wouldn’t it :)  Correction made.  Thank you.
But of course if you want to perform calculations it makes it easier to understand if you assign the value to a variable.
Definitely.  Just throwing a side note out there is all.
