Chief Keeps Locking up on me.
Good afternoon, Chief keeps locking up on me when I try to do the following but not limited to the following items. manager shows that Chief is still running. Any way to fix this issue would be welcomed Thanks
1. When trying to open the roof icon
2. When I group select.
3. While in the walls dialog box trying to change the siding type.
4. When select to open a bulkhead so I could change the size of the bulkhead.
5.. When I use Crl. E to open a kitchen cabinet.
I must go to the task manager box and select end task for Chief and then restart Chief so I can keep working on my plan until the issue happens again. The task manger does show that Chief is still running. Any help with this issues is welcomed
Vinnie
Chief user since X2
Chief Verison X10
OS Microsoft 7 Home Premium
Itel Core I7
64 Bit
16 GB RAM
Make sure your mouse and video card drivers are up to date for your devices. Make sure you have no malware or viruses, physically carefully clean the inside of your computer case (I usually do this myself once a month).
The only time I have had Chief (any version) crash and freeze was from one or more of the above.
I would advise you to exclude Undo / Temp CA Folder from Norton (Symantec) scans.
1) CA Menu> edit> Preferences> Folders>
Look for: "My Undo Folder"  and "My Temporary Folder" and change it to:
C:\Users\<username>\Documents\Chief Architect Premier X11 Data\Temp\
2) Next:
Create that folder "Temp".
3) Open Norton and add the folder exclusion
None of those really put the load ON A graphics card
2) Next:
Vinnie,
Open Chief with a new plan.  It's likely that there's something wrong with the plan you've been using.
If that works then you know it's the plan itself.  You may be able to go back to an archived version of that plan and get that to work.  You can at that point try some of the suggestions BT made as well.
Hi Joe thanks, I opened a few past plans, a new plan file and the same thing keeps happening, it's weird I open the Edit dialog box and the click on preferences and the upper task bar goes gray not letting me in. So, I go back to end task and end CA and start over again.
Vinnie
Hi Vinnie,
Try this:
  • Shut down your computer.
  •  Restart your computer
  • Start Chief without a Plan
  • Click Edit > Preferences
What happens?
If that doesn't work reinstall Chief.  I see you are on X10 so you don't have SSA to get help from CA - but you can pay for their help.
Also, it's possible that an Antivirus program is interfering with Chief Architect.
If you try what Joe suggests, and you are still having problems, then the problems are most likely a system problem.  Could be something like your anti-virus or an actual hardware problem but the most common cause of problems like this is your video card and the drivers.  And yes, the preferences dialog does need to query your video card to get information from your video card so it could cause a lock up too.
More information about trouble shooting video card problems can be found here:
https://www.chiefarchitect.com/support/article/KB-00106/troubleshooting-3d-camera-view-display-problems-in-chief-architect.html
  • 2 months later...
PROBLEM SOLVED. What was going on is that when I clicked on an Icon to open the dialog box, the dialog box was opening on a second monitor that I had, but was not working so I disconnected the monitor.  I couldn't see the dialog box to open it,so when I pushed down the left mouse button all I could hear was the dinging sound. Thanks for you help anyway guys.
Vinnie
    29621
    IndiaCADWorks
    IndiaCADWorks
