Joe_Carrick Posted October 6, 2014 Share Posted October 6, 2014 As long as I've been using Chief, I somehow never got around to learning about the "Sticky Mode" for copying an object. ie: Select an Object, Select Copy, Select the "Sticky Mode" button. This allows you to place the same object many times using the mouse. The Library Objects work this way by default but for Objects selected from the Plan the default is single mode. It would be nice if there was a toggle for "Sticky Mode Copying". Link to comment Share on other sites More sharing options...
DRAWZILLA Posted October 6, 2014 Share Posted October 6, 2014 I use it all the time for Electrical. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted October 6, 2014 Author Share Posted October 6, 2014 On 10/6/2014 at 4:22 PM, DRAWZILLA said: I use it all the time for Electrical. I understand. I just wish there was either a toggle or a default so that when I select an object and the copy tool - I wouldn't have to select the "Sticky Mode Button". IOW, "Sticky Mode" would be persistent from one object to the next. Link to comment Share on other sites More sharing options...
dshall Posted October 6, 2014 Share Posted October 6, 2014 I never use the icon, 0,8 to copy and then 0,4 for sticky mode, I'm with P. I use it all the time. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted October 6, 2014 Author Share Posted October 6, 2014 OK, so I reset my hotkeys for those two commands to F2 and F3 respectfully. That gives me just 2 strokes to get into Copy/Paste_StickyMode. I contemplated using ALT+C & S but I think the 2 Function Keys work better for me. Link to comment Share on other sites More sharing options...
rlackore Posted October 6, 2014 Share Posted October 6, 2014 I had no idea this existed. Thanks. Link to comment Share on other sites More sharing options...
ACADuser Posted October 6, 2014 Share Posted October 6, 2014 Could have used it last week on electrical. I miss the ENTER to repeat the last command. (ACAD works that way, also has option to use Multiple on most commands) To me that is more versatile. Link to comment Share on other sites More sharing options...
chief58 Posted October 6, 2014 Share Posted October 6, 2014 that key has saved a ton of time since they came out with it, use it all the time everyday Link to comment Share on other sites More sharing options...
