Copy - Sticky Mode
Joe_Carrick
As long as I've been using Chief, I somehow never got around to learning about the "Sticky Mode" for copying an object.
ie:  Select an Object, Select Copy, Select the "Sticky Mode" button.
This allows you to place the same object many times using the mouse.  The Library Objects work this way by default but for Objects selected from the Plan the default is single mode.  It would be nice if there was a toggle for "Sticky Mode Copying".
I use it all the time for Electrical.
I understand.  I just wish there was either a toggle or a default so that when I select an object and the copy tool - I wouldn't have to select the "Sticky Mode Button".  IOW, "Sticky Mode" would be persistent from one object to the next.
