buildinthevoid Posted October 2, 2019 Share Posted October 2, 2019 Hey, I'm a newbie here, trying to get the hang of the software. I'm trying to change the interior wall type of one room, but it seems to effect the wall in the room next to it. I tried the break wall tool but the same keeps happening. Link to comment Share on other sites More sharing options...
buildinthevoid Posted October 2, 2019 Author Share Posted October 2, 2019 3 minutes ago, solver said: It's not clear what you are wanting to do. Wall types are Interior-4 or Interior-6 for example -- that is a wall type is a defined wall. Do you want to change the material on a wall? Yeah, I just want to change the material of one wall without it affecting the wall of the room next to it. Link to comment Share on other sites More sharing options...
buildinthevoid Posted October 2, 2019 Author Share Posted October 2, 2019 8 minutes ago, solver said: It's good to know what software you are using. It helps others to have this info in your signature so it's always available. Please see this topic for a signature how to. https://chieftalk.chiefarchitect.com/topic/18908-signature-here-at-chief-talk Using Chief architect Premier x11 Link to comment Share on other sites More sharing options...
Kbird1 Posted October 2, 2019 Share Posted October 2, 2019 1 hour ago, buildinthevoid said: Using Chief architect Premier x11 Put this info in you Signature as the answers to your questions sometimes depend on the version used..... Copy the Walltype ( under define button) and give it a slightly different name and then change the material on one side as needed. M. Link to comment Share on other sites More sharing options...
mmhaupt Posted March 16, 2020 Share Posted March 16, 2020 What happened to the Break Wall Tool in Version 12?? I used it all the time, now it has disappeared with X12. Link to comment Share on other sites More sharing options...
Chrisb222 Posted March 17, 2020 Share Posted March 17, 2020 17 hours ago, mmhaupt said: What happened to the Break Wall Tool in Version 12?? I used it all the time, now it has disappeared with X12. The regular Break tool in the lower edit toolbar now breaks walls too, so the Wall Break tool was taken off the stock toolbar. The Wall Break tool is still there, you can go to Customize Toolbars and add it back to your toolbar. 1 Link to comment Share on other sites More sharing options...
Dermot Posted March 17, 2020 Share Posted March 17, 2020 Chris' answer is correct. For more information about what's new and different in X12, you might want to check out this document: https://cloud.chiefarchitect.com/1/pdf/documentation/chief-architect-x12-migration-guide.pdf Link to comment Share on other sites More sharing options...
LGEURIN Posted Tuesday at 05:56 PM Share Posted Tuesday at 05:56 PM I am trying to use the wall break tool. I find the tool when i search for it in Customize tool bars but how do i get it into my wall tools? Link to comment Share on other sites More sharing options...
Rich_Winsor Posted Wednesday at 07:17 AM Share Posted Wednesday at 07:17 AM You are jumping into a very old post. Much better to start a new thread with your question. That being said you can access the Break Line tool quickly by hitting the 3 key on your keyboard. 1 Link to comment Share on other sites More sharing options...
DBCooper Posted Wednesday at 10:02 PM Share Posted Wednesday at 10:02 PM Quote I am trying to use the wall break tool. I find the tool when i search for it in Customize tool bars but how do i get it into my wall tools? Just to clarify, using the "3" key only works if you first select a wall and if you didn't change your hotkeys. You should also see the "add break" tool in the edit toolbar or on the right-click menu when you select a wall. Also, if you are trying to add the standalone "wall break" toolbar button to your main wall toolbar, you can't. You can add it somewhere else in your custom toolbars but you just can't put it into the "straight wall tools" family (or any other toolbar family for that matter). Link to comment Share on other sites More sharing options...
