Interior wall edits
buildinthevoid
3 minutes ago, solver said:
It's not clear what you are wanting to do. Wall types are Interior-4 or Interior-6 for example -- that is a wall type is a defined wall.
Do you want to change the material on a wall?
Yeah, I just want to change the material of one wall without it affecting the wall of the room next to it.
1 hour ago, buildinthevoid said:
Using Chief architect Premier x11
Put this info in you Signature as the answers to your questions sometimes depend on the version used.....
Copy the Walltype ( under define button) and give it a slightly different name and then change the material on one side as needed.
  • 5 months later...
17 hours ago, mmhaupt said:
What happened to the Break Wall Tool in Version 12??  I used it all the time, now it has disappeared with X12.
The regular Break tool in the lower edit toolbar now breaks walls too, so the Wall Break tool was taken off the stock toolbar.
The Wall Break tool is still there, you can go to Customize Toolbars and add it back to your toolbar.
  • 6 years later...
You are jumping into a very old post. Much better
to start a new thread with your question. That being
said you can access the Break Line tool quickly by
hitting the 3 key on your keyboard.
Quote
I am trying to use the wall break tool.  I find the tool when i search for it in Customize tool bars but how do i get it into my wall tools?
Just to clarify, using the "3" key only works if you first select a wall and if you didn't change your hotkeys.  You should also see the "add break" tool in the edit toolbar or on the right-click menu when you select a wall.
Also, if you are trying to add the standalone "wall break" toolbar button to your main wall toolbar, you can't.  You can add it somewhere else in your custom toolbars but you just can't put it into the "straight wall tools" family (or any other toolbar family for that matter).
