Interior wall edits
buildinthevoid
3 minutes ago, solver said:
It's not clear what you are wanting to do. Wall types are Interior-4 or Interior-6 for example -- that is a wall type is a defined wall.
Do you want to change the material on a wall?
Yeah, I just want to change the material of one wall without it affecting the wall of the room next to it.
1 hour ago, buildinthevoid said:
Using Chief architect Premier x11
Put this info in you Signature as the answers to your questions sometimes depend on the version used.....
Copy the Walltype ( under define button) and give it a slightly different name and then change the material on one side as needed.
  • 5 months later...
17 hours ago, mmhaupt said:
What happened to the Break Wall Tool in Version 12??  I used it all the time, now it has disappeared with X12.
The regular Break tool in the lower edit toolbar now breaks walls too, so the Wall Break tool was taken off the stock toolbar.
The Wall Break tool is still there, you can go to Customize Toolbars and add it back to your toolbar.
  • 6 years later...
You are jumping into a very old post. Much better
to start a new thread with your question. That being
said you can access the Break Line tool quickly by
hitting the 3 key on your keyboard.
