Door Window Numbering
ACADuser
I always have a separate callout for each window and door.  However I do mostly remodels and I want to designate a window as new or existing,  thus,  I have to manually number each window and door,  and at the same time I put a (E) or a (N) designation before each call out.
You will get better results if you do the "existing plus addition" method for title 24 calc's. Sometimes you can't get the addition alone to work without using more expensive windows and extra insulation and more expensive heating a/c systems.
