winterdd Posted July 2, 2019 Share Posted July 2, 2019 chief doesn't have this in the cad details library???? it's one of the most common foundations in the south. Link to comment Share on other sites More sharing options...
dshall Posted July 3, 2019 Share Posted July 3, 2019 I think most of us make our own details since they are all a bit unique. This frees CA up to do more important things. BTW, I am not sure if I ever thanked CA for all the ref set capabilities, if not, I am thanking them now. 1 2 Link to comment Share on other sites More sharing options...
tommy1 Posted July 3, 2019 Share Posted July 3, 2019 12 hours ago, ChiefUserBigRob said: chief doesn't have this in the cad details library???? it's one of the most common foundations in the south. Rob, I'm in Houston, TX and don't know if our details match what you all do there. I have to show a typical exterior wall section (edited for specific situation) along with the foundation detail that specifies steel (rebar) and everything. I also have another detail I use for rebar at corner connections. I can send you a library of these 3 details (cad items) in a Chief library if you like. You could edit them as needed. Email me if interested or call me at 832-754-6160. Link to comment Share on other sites More sharing options...
DG1949 Posted July 3, 2019 Share Posted July 3, 2019 Bonus Catalog>CAD Blocks and Details>CAD Details>Sections>Hot Humid Climates>Energy Efficient Wall Section..... might work as a good staring point. Link to comment Share on other sites More sharing options...
BrownTiger Posted July 3, 2019 Share Posted July 3, 2019 These continuous insulation details probably will not work with hardie or Certainteed or LP SmartSide https://www.jameshardie.com/JamesHardieMainSite/media/Site-Documents/TechnicalBulletins/19-jh-over-advanced-framing-or-continuous-insulation.pdf or Smart LP if you go over 1" requires 2x4s installed as a "strapping" "1-1/2 inches (38 mm) thick by 3-1/2 inches (89 mm) wide vertical strap or furring strip must be installed over the sheathing to provide a solid level nailing base for the siding" Only with Vinyl ( it could and will look buckled because of a foam compression) Link to comment Share on other sites More sharing options...
ShaneK Posted July 3, 2019 Share Posted July 3, 2019 Slab detail.plan Link to comment Share on other sites More sharing options...
