4hotshoez Posted September 23, 2014 Share Posted September 23, 2014 I regularly design openings with craftsman style head casing and crown. Currently I do not see a way to do that in Chief. Any ideas? Link to comment Share on other sites More sharing options...
4hotshoez Posted September 23, 2014 Author Share Posted September 23, 2014 Ah! I found it. "Use Interior Lintel". Now I need to create a profile. Thanks for your help. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted September 23, 2014 Share Posted September 23, 2014 There is already a crosshead in the lib. Link to comment Share on other sites More sharing options...
JLDrafting Posted September 23, 2014 Share Posted September 23, 2014 There is already a crosshead in the lib. Yes there is. Link to comment Share on other sites More sharing options...
4hotshoez Posted September 23, 2014 Author Share Posted September 23, 2014 I have looked at all the libraries I have and do not find it. Is it a bonus Lib? Link to comment Share on other sites More sharing options...
JLDrafting Posted September 23, 2014 Share Posted September 23, 2014 I have looked at all the libraries I have and do not find it. Is it a bonus Lib? Architectural>Millwork> Mantels, lintels Link to comment Share on other sites More sharing options...
Joe_Carrick Posted September 23, 2014 Share Posted September 23, 2014 If you make a Molding Profile you can use that with "Wrap" checked within the Door dbx. The Lintel Symbol has to be manually placed. It's not connected to the Door like a Molding Profile is. 1 Link to comment Share on other sites More sharing options...
4hotshoez Posted September 24, 2014 Author Share Posted September 24, 2014 The millwork section has various 2D shapes (like CA-22) that can be used as extrusions, but how can I open them and edit to create my own by adding or changing a shape? Or even use one in a CAD detail? Link to comment Share on other sites More sharing options...
glennw Posted September 24, 2014 Share Posted September 24, 2014 I assume that you are talking about Moldings and not Millwork - there is a difference. To work on a Molding profile, use it on a molding polyline. Take a cross section through the Molding. Cad Detail from View. You can now edit the shape, copy, paste, etc. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted September 24, 2014 Share Posted September 24, 2014 This time Glenn is wrong. Select a Molding in the Library (Right Mouse Click) and select "Place Molding Profile" from the context menu. Then place the profile in your drawing, edit it and "Add to Library" the new profile. Link to comment Share on other sites More sharing options...
glennw Posted September 24, 2014 Share Posted September 24, 2014 Joe, Yes, you are correct. But I don't think that I was wrong - it does work that way. But, yes, yours is the better and easiest way. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted September 24, 2014 Share Posted September 24, 2014 Glenn, Sorry for being so emphatic. I agree you were not really wrong but since you so often have the best answer - I just couldn't resist Link to comment Share on other sites More sharing options...
ACVNarch Posted June 23, 2023 Share Posted June 23, 2023 Where did that "boxed" lintel go? -It's not in my x14 library (almost ten years later) Link to comment Share on other sites More sharing options...
